Zotac GeForce GTX 750 Ti Low Profile (2GB) Graphics Card PCI
Quicklinx: B1Z0WS00 Mfr#: ZT-70606-10M
  • NVIDIA GeForce GTX 750 Ti
Experience superior gaming with the ZOTAC GeForce GTX 750 Ti graphics card. Engineered from the ground up for maximum performance and efficiency, the ZOTAC GeForce GTX 750 Ti graphics card delivers the performance gamers crave with optimal features that elevate PC gaming to the high level and a 60-percent greater energy-efficiency.
The ZOTAC GeForce GTX 750 Ti graphics card supports the game-changing features including GeForce ShadowPlay to automatically capture the last 20-minutes of gaming to share your epic frags or live stream your gameplay with minimal performance impact. NVIDIA GeForce Experience support enables the ZOTAC GeForce GTX 750 Ti graphics card to run very demanding games with the fine combination of performance and visual quality without additional tweaking.
ZOTAC GeForce GTX 750 Ti LP - graphics card - GF GTX 750 Ti - 2 GB
Graphics card - low profile
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1033 MHz
Boost Clock
1111 MHz
CUDA Cores
640
Effective Memory Clock
5.4 GHz
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
3840 x 2400
Max Resolution Details
HDMI: 3840 x 2400 at 30 Hz / DVI: 2560 x 1600 at 120 Hz
Max Monitors Supported
3
DVI-D (dual link) , VGA , HDMI
API Supported
OpenGL 4.4, DirectX 12
14.884 cm x 11.115 cm
3-year warranty with product registration
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1033 MHz
Boost Clock
1111 MHz
CUDA Cores
640
RAMDAC
400 MHz
Max Resolution
3840 x 2400
3
API Supported
Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, NVIDIA Adaptive Vertical Sync, Nvidia SMX Engine, NVIDIA GPU Boost 2.0, NVIDIA Project SHIELD Ready, Nvidia GeForce ShadowPlay, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5.4 GHz
Bus Width
128-bit
Microsoft Windows 7 / Windows 8 (32 bits), Microsoft Windows 7 / Windows 8 (64 bits)
Required Power Supply
400 W
60 Watt
2 low-profile brackets
Software Included
Drivers & Utilities
C-Tick, FCC, RoHS, WEEE
14.884 cm
11.115 cm
Limited warranty - 3 years
