Zotac GeForce GTX 470 1280MB PCI-Express HDMI (Fermi)
Quicklinx: 6N88WS00 Mfr#: ZT-40201-10P
  • High-Definition Multimedia Interface (HDMI)
Propel your computing power to uncharted heights with the class-leading ZOTAC GeForce® GTX 470 graphics card designed for phenomenal performance in gaming and GPU computing applications. The ZOTAC GeForce® GTX 470 features compatibility with the latest Microsoft® DirectX® 11 and OpenGL® 3.2 games and applications while enhancing the experience with realistic physics processing through NVIDIA® PhysX® technology and superior gaming immersion with NVIDIA® 3D Vision™ Surround technology.
NVIDIA® CUDA™ technology with DirectCompute and OpenCL support harnesses the power of the graphics processor in the ZOTAC GeForce® GTX 470 and takes it beyond the heights of gaming by accelerating the most demanding tasks such as image and video editing for incredible performance improvements unmatched by traditional system CPUs. Dual dual-link DVI and mini-HDMI outputs with HDCP compliance ensures the ZOTAC GeForce® GTX 470 to connect up to three digital monitors or high-definition televisions for crystal clear clarity.
  • Stunning gaming effects
    Cutting-edge Microsoft DirectX 11 graphics and NVIDIA PhysX technology take gaming to a new level. Witness effects so realistic that you'll have to remind yourself it's just a game. Repeat: It's just a game.
  • Total immersion
    Games, movies and photos enter a dimension with NVIDIA 3D Vision technology. Thrill seeker? Use two GeForce GTX 480 cards in NVIDIA SLI configuration to project across three displays with NVIDIA 3D Vision Surround technology.
  • Futuristic graphics
    Prepare yourself for the future of gaming. GeForce GTX 480 powers interactive raytracing, bringing spectacular, photo-realistic renderings to your screen for the first time. Go ahead, spoil your eyes.
ZOTAC GeForce GTX 470 - graphics card - GF GTX 470 - 1.25 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GTX 470 - up to
1.25 GB GDDR5
Core Clock
607 MHz
Effective Memory Clock
3.348 GHz
RAMDAC
400 MHz
Memory Interface
320-bit
Max Resolution
2560 x 1600
Max Monitors Supported
2
Interfaces Details
2 x DVI-I (dual link) , HDMI , VGA - with adapter , HDMI - with adapter
API Supported
DirectX 11, OpenCL, OpenGL 3.2, DirectCompute
6.78 cm x 33.7 cm x 26 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
607 MHz
RAMDAC
400 MHz
Max Resolution
2560 x 1600
2
Interfaces Details
API Supported
Nvidia SLI Multi-GPU Technology, Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, HDCP
Size
1.25 GB
GDDR5 SDRAM
Effective Clock Speed
3.348 GHz
Bus Width
320-bit
Microsoft Windows Vista / XP / 7
Additional Requirements
Two additional power connectors
6 pin power cable, Dual 6-pin PCIe to 8-pin power adapter
1 x DVI-VGA adapter , 1 x mini HDMI-HDMI adapter
Software Included
Drivers & Utilities
Supported Windows 7 Features
Windows Media Center
RoHS
6.78 cm
33.7 cm
26 cm
0.9 kg
