Zotac GeForce GTX 1060 AMP Edition 6GB GDDR5 PCIe 3.0 x16 DVI HDMI DisplayPort
Quicklinx: CP8QWS00 Mfr#: ZT-P10600B-10M
The GeForce GTX 1060 graphics card is loaded with innovative new gaming technologies, making it the perfect choice for the latest high-definition games. Powered by NVIDIA Pascal - the most advanced GPU architecture ever created - the GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond.
  • The world's most advanced GPU architecture
    GeForce GTX 10-series graphics cards are powered by Pascal to deliver up to 3x the performance of previous-generation graphics cards, plus innovative new gaming technologies and breakthrough VR experiences. The GeForce GTX 1060 takes advantage of Pascal to significantly improve speed and power efficiency.
  • GeForce GTX 10-Series GPUs have come to laptops
    Gamers can now experience the power and performance of GeForce GTX 10-Series GPUs in a mobile form factor. These notebooks give you everything you need to unleash your gaming dominance by turning your mobile rig into a sleek, powerful gaming weapon.
  • Founders edition graphics cards
    The GeForce GTX 1060 6 GB Founders Edition graphics card is crafted by NVIDIA engineers with premium materials and components. Plus, it features brilliant thermals that keep the GPU cool under even the most intense gaming conditions.
ZOTAC GeForce GTX 1060 - AMP! Edition - graphics card - GF GTX 1060 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060 - up to
6 GB GDDR5
Core Clock
1556 MHz
Boost Clock
1771 MHz
CUDA Cores
1280
Effective Memory Clock
8 GHz
Memory Interface
192-bit
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , 3 x DisplayPort , HDMI
API Supported
OpenCL, DirectX 12, OpenGL 4.5, Vulkan, DirectX 12.1
21 cm x 12.8 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1556 MHz
Boost Clock
1771 MHz
CUDA Cores
1280
VR Ready
4
Interfaces Details
API Supported
NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, NVIDIA Ansel, HDCP
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8 GHz
Bus Width
192-bit
Microsoft Windows 7 / 8 / 10
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
120 Watt
Dual 4-pin to 6-pin PCIe adapters
21 cm
12.8 cm
