Make your entire PC experience faster with the advanced GT 710 dedicated graphics card. Now, you can enjoy better performance than integrated graphics in all your favorite PC applications delivering rock-solid reliability and stability.
- ZOTAC GeForce GT 710 - graphics card - GF GT 710 - 2 GB
- Graphics card
- Bus Type
- PCI Express 2.0
- Graphics Engine
- NVIDIA GeForce GT 710
- Memory
- 2 GB DDR3
- Core Clock
- 954 MHz
- CUDA Cores
- 192
- Effective Memory Clock
- 1600 MHz
- Memory Interface
- 64-bit
- Max Monitors Supported
- 3
- Interfaces Details
- DVI-D (dual link) , VGA , HDMI
- API Supported
- OpenCL, DirectX 12, OpenGL 4.5
- Fanless
- 14.605 cm x 11.115 cm
- Graphics card - fanless
- Bus Type
- PCI Express 2.0
- Graphics Engine
- Core Clock
- 954 MHz
- CUDA Cores
- 192
- 3
- API Supported
- Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), HDCP
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1600 MHz
- Bus Width
- 64-bit
- OS Required
- Microsoft Windows XP / Vista / 7 / 8 / 10
- Required Power Supply
- 300 W
- Included Accessories
- Low-profile bracket
- Software Included
- Driver
- 14.605 cm
- 11.115 cm
