Zoostorm Stormforce Phantom Core i5-6600k Skylake 16GB 2TB 128GB SSD GTX-980 Windows 10 Home 64-bit
Quicklinx: BVNJWS00 Mfr#: 7877-0882
  • Core i5
Videos are crisper, gaming is more versatile and performance is more efficient with an Intel® Core™ i5 processor. Systems and devices work smarter than ever with an automatic burst of speed when needed with Intel® Turbo Boost Technology. The massive 3TB hard drives provides masses of space to store all your media files and documents, enough for around 750,000 songs, 360 hours of HD video or 600,000 10MP digital photos.
• Intel Core i5-6600K 3.5ghz CPU (Overclocked to 4.4GHz)
• Cache: 6MB
Cooling
• Water Cooling System
• 16GB DDR4 2133Mhz RAM
• Supports up to 64GB
• 4 x DIMM sockets (2 used)
Hard Drive
• 2TB SATA HDD
• 128GB SSD
Optical Drive
• DVDRW
Software
• Operating System: Windows© 10 Home
Chipset
• Intel Z170
Display
• N/A
Graphics
• GTX-980 Graphics Card
Audio
• High Definition Audio, 7.1 channel*
• Realtek 10/100/1000 LAN
Power Supply
• 500 watts
Dimensions
• Height: 530mm
• Width: 195mm
• Depth: 529mm
• 1 x PS/2 Port
• 1 x HDMI Port
• 1 x DVI-I Port
• 1 x Display Port
• 8 x USB 3.0 Port
• 1 x RJ-45 Port
• 3 x Audio Jacks
Expansion
• 2 x PCI-e x 16 Slot**
• 2 x PCI-e x 1 Slots
• 6 x 3.5" Internal Bays (1 used)
• 6 x 2.5" Internal Bays (1 used)
• 3 x 5.25" External Bays (1 used)
Case
• White Mana Case
Warranty / Miscellaneous
• 1 Year Collect and Return Warranty
To configure 7.1-channel audio, you have to use an HD front panel audio module and enable the multi-channel audio feature through the audio driver.
The secondary PCIEX16 slot runs at x4 speeds and shares bandwidth with the PCI Express x1 slots. When the PCI Express x1 slots are populated, the PCIEX4 slot will operate at up to x1 mode.
