Zoostorm Intel Core i5-3340 4GB 500GB Windows 7 Pro Mouse + Keyboard
EXCLUSIVE TO BT! LAST FEW STOCKS REMAINING!
Quicklinx: 93CLWS00 Mfr#: 7877-0413
  • Core i5
  • Microsoft Windows 7 Professional
For companies and organisations that need advanced computing power for tasks such as graphic design, large data file processing and advanced office analysis, our range of high performance business PCs take advantage of the latest high performance components and deliver a staggeringly quick and powerful computing experience.
All Zoostorm Business PCs are designed around the principles of productivity, longevity and low costs of ownership. These PCs are also designed to be space saving and configured to work with popular business applications such as Office, database and communication.
All Zoostorm business PCs are ready to network out of the box and feature Windows® 7 Professional.
Zoostorm Business systems are pre-installed with Windows© 7 Professional along with the latest service pack. Inside the Zoostorm business PC is the very latest Intel® Hyper-Threading Technology and our Core i5 model automatically speed up (overclocks) your PC when you need it. Intel's new Turbo Boost technology is equipped to handle the most demanding of applications. All Zoostorm business machines feature Ethernet connection and if productivity, reliability and results matter to your business, you can't do any better than a Zoostorm desktop solution.
A durable keyboard and mouse are also provided with the package. This system features a 1 year on-site parts and labour warranty.
Intel Core i5-3340 (6M Cache. 3.1GHz)
RAM
4GB DDR3 Memory - 2 x DIMM (1 free)
Hard Drive
1 x 500GB 7200rpm SATA HDD
OS Provided
Optical
DVD-RW
Included peripherals
Keyboard & Mouse
Standard Warranty
1 Year
Network Interface
10/100/1000 LAN
Dimensions D x W x H
400mm x 180mm x 360mm
Boxed Weight
12.5kg
Internal Expansion
1 x PCI-e x 16 slot (free), 2 x PCI-e x 1 slot (free), 4 x SATA ports (2 free)
1 set 5.1 channel audio jacks (3 jacks), 2 x PS/2 ports, 6 x USB 2.0 ports, 1 x RJ45 LAN port, 1 x DVI-D port, 1 x VGA port
