Maximise your Workspace
This Ultra Small Form Factor Mini Desktop PC combines the performance of a fully-equipped desktop PC all packed in to a smaller space saving chassis, with low energy consumption and a large number of practical connections such as USB 2.0 and Wi-Fi.
Windows 10 Home
Windows 10 is familiar and easy to use, with lots of similarities to Windows 7 including the Start menu. It starts up and resumes fast, has more built-in security to help keep you safe and is designed to work with software and hardware that you already have.
Performance and Value you Can Count on
Intel Celeron processors deliver high-performance for everyday computing. Receive performance, serious processing and value with Intel Inside.
Intel HD Graphics – Vibrant Visuals Built In
See your content the way it is meant to be seen—in vibrant, dazzling clarity. Immerse yourself in rich, vivid visuals enabled by integrated Intel HD Graphics.
- Processor
- Intel® Core i3-6100U (6th Generation
- Processor Base Frequency: 2.3GHz
- Cache: 3MB SmartCache
- Memory
- 4GB DDR3 1600MHz RAM
- Supports up to 16GB
- 2x So-DIMM sockets (1 used)
- Hard Drive
- 128GB M.2 SSD
- Optical Drive
- None
- Software
- Operating System: Windows 10 Home
- Microsoft Office not included
- Motherboard
- Gigabyte Brix
- Display
- N/A
- Graphics
- On-board integrated Intel® HD Graphics 520
- Audio
- Realtek ALC255
- Input Devices
- Keyboard and Mouse Not Supplied
- Networking
- Dual Band WiFi
- Dimensions
- Height: 34.4mm
- Width: 112.6mm
- Depth: 119.4mm
- 1x HDMI
- 1x Mini DisplayPort
- 4 x USB 3.0 Port
- 1x RJ45 port
- 2x Audio Jacks
- 1x Kensington Lock Slot
- Expansion
- 1 x PCI-e M.2 Slot (used)
- 1x M.2 SSD Slot (used)
- Case
- · USFF Tower Case
- Warranty / Miscellaneous
- 2 Year Return to Base Warranty
Hard Drive
- 128GB M.2 SSD
Optical Drive
- None
Software
Motherboard
- Gigabyte Brix
Display
- N/A
Graphics
Audio
- Realtek ALC255
Input Devices
- Dual Band WiFi
Dimensions
- Height: 34.4mm
- Width: 112.6mm
- Depth: 119.4mm
- 1x HDMI
- 4 x USB 3.0 Port
- 1x RJ45 port
- 2x Audio Jacks
Expansion
Case
- · USFF Tower Case
