Zoostorm 7240-6078 Intel Core PDC G4400 4GB 1TB Windows 10 Pro
Quicklinx: C4JCWS00 Mfr#: 7240-6078
Designed to meet the rigours of the classroom, the Delta Elite from Zoostorm™ is a compact, durable system, offering improved ‘Storm Coat’ paint durability and scratch resistance.
With a minimum 8 year design life, fans rated for over 50,000 hours and 85% PSU efficiency, the Delta Elite delivers outstanding performance and improved reliability for many years to come. Panels on both sides of the system will prevent dust and debris entering the chassis, reducing the risk of internal component damage.
Zoostorm™ is manufactured and supported in the UK and has built its reputation on delivering excellent quality, service and support.
