The Model 5801 is a Voice over IP Telephone Adapter, which allows standard analog telephones to make and receive calls over a cable or ADSL Internet connection. A conventional phone or cordless phone is plugged into the adapter and then the adapter is plugged into a broadband connected router or Internet gateway. A minimum of five attached phones can be rung simultaneously using the built-in ring generator. The model supports industry-standard Session Initiation Protocol (SIPv2) and works with a wide range of service providers and SIP-based VoIP equipment. The Model 5801 also supports G.711 and iLBC Codecs.
- Zoom Model 5801 Voice over IP Telephone Adapter - VoIP phone adapter
- Form Factor
- External
- Data Link Protocol
- Ethernet
- VoIP Protocols
- SIP v2
- Telephony Interfaces
- 1 phone (FXS), 1 line (FXO)
- 14.6 cm x 11.2 cm x 2.8 cm
- 14.6 cm
- 11.2 cm
- 2.8 cm
- Form Factor
- External
- Connectivity Technology
- Wired
- Ethernet
- TCP/IP, UDP/IP, ICMP/IP
- Remote Management Protocol
- HTTP
- Status Indicators
- Power, link/activity
- DHCP support, RARP support, ARP support, DiffServ support, SNTP support, Trivial File Transfer Protocol (TFTP) support
- Encryption Algorithm
- MD5, ARCFOUR
- IEEE 802.1Q, IEEE 802.1p
IP Telephony
- VoIP Protocols
- SIP v2
- Voice Codecs
- G.711, iLBC
- IP Telephony Features
- Echo cancellation (G.168), call forwarding, call waiting, echo cancellation (G.165), call hold, message waiting
- 1 x modem - RJ-11 , 1 x modem - RJ-11 , 1 x Ethernet
- RoHS
- Power Device
- External power adapter
