ZOOM VOIP ATA 1FXS
ZOOM VOIP ATA 1FXS
Quicklinx: 74Q4WS00 Mfr#: 5801-72-11F
The Model 5801 is a Voice over IP Telephone Adapter, which allows standard analog telephones to make and receive calls over a cable or ADSL Internet connection. A conventional phone or cordless phone is plugged into the adapter and then the adapter is plugged into a broadband connected router or Internet gateway. A minimum of five attached phones can be rung simultaneously using the built-in ring generator. The model supports industry-standard Session Initiation Protocol (SIPv2) and works with a wide range of service providers and SIP-based VoIP equipment. The Model 5801 also supports G.711 and iLBC Codecs.
Zoom Model 5801 Voice over IP Telephone Adapter - VoIP phone adapter
VoIP phone adapter
External
Ethernet
VoIP Protocols
SIP v2
Telephony Interfaces
1 phone (FXS), 1 line (FXO)
14.6 cm x 11.2 cm x 2.8 cm
VoIP phone adapter
14.6 cm
11.2 cm
2.8 cm
External
Wired
Ethernet
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP
Remote Management Protocol
HTTP
Status Indicators
Power, link/activity
DHCP support, RARP support, ARP support, DiffServ support, SNTP support, Trivial File Transfer Protocol (TFTP) support
Encryption Algorithm
MD5, ARCFOUR
IEEE 802.1Q, IEEE 802.1p
IP Telephony
VoIP Protocols
SIP v2
Voice Codecs
G.711, iLBC
IP Telephony Features
Echo cancellation (G.168), call forwarding, call waiting, echo cancellation (G.165), call hold, message waiting
1 x modem - RJ-11 , 1 x modem - RJ-11 , 1 x Ethernet
RoHS
External power adapter
