Zoom ADSL X6 Router Wireless Access Point 4 Port Switch
Quicklinx: 761FWS00 Mfr#: 5690-72-00AG
This versatile product provides a shared ADSL Internet connection for up to 253 computers, game stations, WiFi - enabled phones, and other devices connected wirelessly, via this product's 4 Ethernet LAN ports, or through a switching hub or other network device. Plug the X6's phone cord into a phone line with ADSL service. Then use the X6's built-in wireless capability and/or its 4 Ethernet ports to connect computers, Ethernet switches, HomePlug® adapters, or other devices. Setup is easy using any Web browser. The X6 supports all popular ADSL protocols, and delivers download speeds up to 24 Mbps. Best of all, the X6 is produced and supported by Zoom Telephonics, a communication products leader since 1977.
Optional Use As A Router
If you choose to use the X6's router features, you'll enjoy its flexibility, friendly user interface, and extensive features. The router features are useful for all the computers and other devices plugged directly into the X6, connected to the X6 wirelessly, or linked to the X6 through a switching hub, HomePlug, or other network connection. Extensive X6 router features include WPA2/WPA/WEP wireless security, support for up to 4 SSIDs, WDS, an SPI/NAT firewall, Denial of Service attack protection, IP filtering, Virtual Server, DMZ, LAN and WAN access control, online gaming support, extensive debugging and diagnostic tools, and much more. The friendly X6 graphical user interface makes it easy for you to use your favorite browser to set any router feature you like, even from remote locations.
Zoom ADSL X6 5690 - wireless router - DSL modem - 802.11b/g - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+
Ethernet, ATM, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, AAL5, IPoA
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP
Firewall protection, switching, DHCP support, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, firmware upgradable, Quality of Service (QoS), virtual server support
IEEE 802.3, IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, UPnP
AC 120/230 V (50 - 60 Hz)
17.8 cm x 13.7 cm x 3.3 cm
1-year warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
Routing Protocol
RIP-1, RIP-2
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Authentication Method
PAP, CHAP
IEEE 802.3, IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, UPnP, FCC Part 15 B, FCC Part 68, CS-03, RoHS
Status Indicators
Port status, power, WLAN, link/activity
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5
Max Transfer Rate
24 Mbps
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Phone line: 1 x ADSL - RJ-11
Aerial
Antenna Qty
1
External power adapter
1 x network cable , 1 x phone cable
17.8 cm
13.7 cm
3.3 cm
Limited warranty - 1 year
Resources
The following resources are available for the Zoom ADSL X6 Router Wireless Access Point 4 Port Switch
