Zigor EBRO 650 UPS
Zigor EBRO 650 UPS
Quicklinx: B9HPWS00 Mfr#: 18595
Designer UPS with a capacity of 600VA/360 Watt, specially designed to protect computers and electronic audio-video devices. The Ebro line offers a hybrid solution of sockets and IEC sockets to back up any connectable electronic devices.
The Ebro 650 combines design, versatility and easy operation, offering 4 sockets, 2 UPS mode and 2 lightning arresters, and 2 UPS mode IEC sockets. Includes 2 communications ports, USB and RJ11 for tel/fax/modem protection. With its IN-LINE technology and built-in voltage regulator, the Ebro 650 can protect against overvoltages, stabilize micro power cuts and provides back-up in the case of power failures. This technology allows for optimum operation of the UPS as well as the efficient use of the battery, prolonging its service life. Moreover, the Ebro 650 allows you to protect your data in the case of a prolonged power failure.
  • Uninterrupted power
    Protects your data by supplying battery power in the case of a mains failure.
  • Microprocessor control
    The circuits of the UPS are managed by a microprocessor that reduces the size of the UPS and increases its reliability.
  • Visual Led alarms
    The status of the UPS is shown in the unit.
  • Acoustic alarm
    The device warns you when it is running on battery, if the battery is low or the UPS is in overload.
  • High-quality battery
    The air-tight, maintenance-free lead battery ensures long service life to improve economy of operation.
  • Automatic detection
    When the UPS is turned on, it automatically inspects the battery capacity.
  • Protection against overvoltages
    Protects equipment connected to the UPS in the case of mains overvoltages.
  • Automatic charging
    The UPS charges the battery whenever it is connected to the mains electricity and is on.
Zigor Ebro 650 - UPS - 960 Watt - 650 VA
UPS - external
Power Capacity
960 Watt / 650 VA
UPS - external
UPS Technology
Line interactive
Power Capacity
960 Watt / 650 VA
