The ZXP series 3 is unique to the card printing market, employing several advanced features that provide high performance at an attractive price. The ZRaster host-based image processing technology takes advantage of the increased processing power of today's PCs to significantly optimize image and print quality while increasing overall print speed throughput. This permits greater sophistication in the image optimizations without sacrificing printer speed or adding extra cost. Zebra high performance ribbons employ an improved chemical formulation specifically designed for fast high-quality image printing, providing more efficient dye transfer and greater durability under high-speed printing conditions.
Efficient media handling
Designed to accommodate CR-80 Card (85.6 x 54 mm), the Zebra ZXP Series 3 printer ensures seamless media handling for a variety of printing needs. Its automatic media feeder with a capacity of 100 cards enhances productivity and supports continuous printing operations. -
Versatile connectivity
With its wired connectivity technology, this printer offers reliable and secure connections to a range of devices, ensuring consistent printing performance. -
Optimal operating range
The printer operates efficiently within a temperature range of 15°C to 30°C, ensuring high-quality output in various environmental conditions. This adaptability makes it suitable for a wide range of office settings.
- Zebra ZXP Series 3 - plastic card printer - colour - dye sublimation
- Printer Type
- Plastic card printer - dye sublimation - colour
- 5.3 kg
- Localisation
- United Kingdom, Europe
- Max Media Size
- CR-80 Card (85.6 x 54 mm)
- Max Media Size (Custom)
- 85.6 mm x 54 mm
- Print Speed
- Up to 700 cards/hour - monochrome - CR-80 Card (85.6 x 54 mm) , Up to 180 cards/hour - colour single-sided - CR-80 Card (85.6 x 54 mm)
- Max Resolution (B&W)
- 300 dpi
- Interface
- USB 2.0, LAN
- RAM Installed (Max)
- 32 MB
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, Interleaved 2 of 5, PDF417, Code 128B, Code 128C
- Media Type
- Cards, PVC composite card, PVC card
- Total Media Capacity
- 100 cards
- Networking
- Print server
- Printer Features
- Zebra ZRaster technology
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista / XP, Microsoft Windows Server 2008
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- 20 cm x 36.8 cm x 23.6 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB 2.0, LAN
- 300 dpi
- Barcodes
- Printer Features
RAM
- 32 MB
Media Handling
- Media Type
- Max Media Size
- 85.6 mm x 54 mm
- Card / Label Sizes
- 100 cards
- Media Feeders
- 1 x automatic - 100 cards - CR-80 Card (85.6 x 54 mm)
- Max Media Capacity
- 100 cards
- Output Trays Capacity
- 45 cards
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Cables Included
- 1 x USB cable
- FCC Class A certified
- Power Device
- Power adapter
- Frequency Required
- 50/60 Hz
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years , Limited warranty - printhead - 2 years
- 15 °C
- 30 °C
- 20 - 65% (non-condensing)
- 20 cm
- 36.8 cm
- 23.6 cm
- 5.3 kg
