Zebra ZXP3 SS STD + Ethernet
Quicklinx: C5NZWS00 Mfr#: Z31-000C0200EM00
The ZXP series 3 is unique to the card printing market, employing several advanced features that provide high performance at an attractive price. The ZRaster host-based image processing technology takes advantage of the increased processing power of today's PCs to significantly optimize image and print quality while increasing overall print speed throughput. This permits greater sophistication in the image optimizations without sacrificing printer speed or adding extra cost. Zebra high performance ribbons employ an improved chemical formulation specifically designed for fast high-quality image printing, providing more efficient dye transfer and greater durability under high-speed printing conditions.
  • Efficient media handling
    Designed to accommodate CR-80 Card (85.6 x 54 mm), the Zebra ZXP Series 3 printer ensures seamless media handling for a variety of printing needs. Its automatic media feeder with a capacity of 100 cards enhances productivity and supports continuous printing operations.
  • Versatile connectivity
    With its wired connectivity technology, this printer offers reliable and secure connections to a range of devices, ensuring consistent printing performance.
  • Optimal operating range
    The printer operates efficiently within a temperature range of 15°C to 30°C, ensuring high-quality output in various environmental conditions. This adaptability makes it suitable for a wide range of office settings.
Zebra ZXP Series 3 - plastic card printer - colour - dye sublimation
Printer Type
Plastic card printer - dye sublimation - colour
5.3 kg
United Kingdom, Europe
Max Media Size
Max Media Size (Custom)
85.6 mm x 54 mm
Print Speed
Up to 700 cards/hour - monochrome - CR-80 Card (85.6 x 54 mm) , Up to 180 cards/hour - colour single-sided - CR-80 Card (85.6 x 54 mm)
Max Resolution (B&W)
300 dpi
USB 2.0, LAN
RAM Installed (Max)
32 MB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, Interleaved 2 of 5, PDF417, Code 128B, Code 128C
Media Type
Cards, PVC composite card, PVC card
Total Media Capacity
100 cards
Print server
Printer Features
Zebra ZRaster technology
Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista / XP, Microsoft Windows Server 2008
Microsoft Certification
Compatible with Windows 7
20 cm x 36.8 cm x 23.6 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB 2.0, LAN
300 dpi
Barcodes
Printer Features
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Max Media Size
85.6 mm x 54 mm
Card / Label Sizes
100 cards
Media Feeders
1 x automatic - 100 cards - CR-80 Card (85.6 x 54 mm)
Max Media Capacity
100 cards
Output Trays Capacity
45 cards
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
1 x USB cable
FCC Class A certified
Power adapter
Frequency Required
50/60 Hz
Environmental Standards
ENERGY STAR
Limited warranty - 2 years , Limited warranty - printhead - 2 years
15 °C
30 °C
20 - 65% (non-condensing)
20 cm
36.8 cm
23.6 cm
5.3 kg
