The ZXP Series 1 card printer has been designed specifically for customers who need a quality printer at a competitive price. Ideal for low-volume, single-sided printing applications in color or monochrome, the ZXP Series 1 offers a complete card printing solution with a minimal upfront investment. Its Energy Star certification and eco-friendly print cartridges make it the best entrylevel printer on the market.
The ZXP Series 1 requires little technical support or user training. Operation is made simple with intuitive user interface and color touch points. The quick-replace Load-N-Go smart ribbons have the added benefit of being eco-friendly, using less plastic and more biodegradable material. Print touch uses near field communication (NFC) to instantly retrieve helpful information about the ZXP Series 1 from any NCF-enabled smart device.
A small footprint allows the ZXP Series 1 to fit in the tightest workspaces, making it the right choice when space is limited. Its compact and durable design and advanced network printer management software tools, make the ZXP Series 1 a perfect for multiple small office installations, or large deployments of distributed card printers.
You can count on the ZXP Series 1 to print clear, sharp and color rich images when you need them, and where you need them. Its optional magnetic stripe encoding, Ethernet connectivity, and support for multiple card thicknesses permit the ZXP Series 1 to meet a variety of business and ID card needs.
Affordable, entry-level printer
The ZXP Series 1 card printer has been designed specifically for customers who need a quality printer at a competitive price. Ideal for low-volume, single-sided printing applications in color or monochrome, the ZXP Series 1 offers a complete card printing solution with a minimal upfront investment. Its Energy Star certification and eco-friendly print cartridges make it the best entrylevel printer on the market. -
Ease of use
The ZXP Series 1 requires little technical support or user training. Operation is made simple with intuitive user interface and color touch points. The quick-replace Load-N-Go smart ribbons have the added benefit of being eco-friendly, using less plastic and more biodegradable material. Print touch uses near field communication (NFC) to instantly retrieve helpful information about the ZXP Series 1 from any NCF-enabled smart device. -
Compact size and network manageable
A small footprint allows the ZXP Series 1 to fit in the tightest workspaces, making it the right choice when space is limited. Its compact and durable design and advanced network printer management software tools, make the ZXP Series 1 a perfect for multiple small office installations, or large deployments of distributed card printers. -
No compromise high quality cards
- Zebra ZXP Series 1 - plastic card printer - colour - dye sublimation
- Printer Type
- Plastic card printer - dye sublimation - colour
- 5.3 kg
- Localisation
- United Kingdom, Europe
- Max Media Size
- CR-80 Card (85.6 x 54 mm)
- Max Media Size (Custom)
- 85.6 mm x 54 mm
- Print Speed
- Up to 500 cards/hour - monochrome - CR-80 Card (85.6 x 54 mm) , Up to 120 cards/hour - colour single-sided - CR-80 Card (85.6 x 54 mm)
- Max Resolution (B&W)
- 300 dpi
- Interface
- USB 2.0
- Media Type
- Cards, PVC composite card, PVC card
- Total Media Capacity
- 100 cards
- Printer Features
- Zebra ZRaster technology
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- 20 cm x 33 cm x 23.6 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 300 dpi
- Printer Features
Media Handling
- Media Type
- Max Media Size
- 85.6 mm x 54 mm
- Card / Label Sizes
- 100 cards
- Media Feeders
- 1 x automatic - 100 cards - CR-80 Card (85.6 x 54 mm)
- Max Media Capacity
- 100 cards
- Output Trays Capacity
- 45 cards
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Included Accessories
- Cleaning kit, web camera
- Cables Included
- 1 x USB cable
- Consumables Included
- 1 x ribbon (yellow/cyan/magenta/black/overcoat)
- Media Included
- 100 PVC cards
- FCC Class A certified, ISO 7811, ISO 7810
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities, Zebra ZMotif CardStudio Standard
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years , Limited warranty - printhead - 2 years
- 15 °C
- 30 °C
- 20 - 65% (non-condensing)
- 20 cm
- 33 cm
- 23.6 cm
- 5.3 kg
