Zebra ZT230 Mono Label Printer
Quicklinx: 8DMPWS00 Mfr#: ZT23042-T0E200FZ
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
More than 50 in stock
£693.34 ex VAT
£832.00 inc VAT
Zebra incorporated extensive customer feedback to create the ZT200 series printers, which feature space-saving design, effortless setup, intuitive user operation, and ease of service and maintenance.
Whether you are adopting barcode technology for the first time or upgrading existing printer models, the ZT200 series is the right choice for a variety of labeling applications. This innovative printer provides many user benefits
The ZT200 series offers a streamlined design and smaller footprint. ZT200 series printers require minimal operator training and benefit from tool-less standard component maintenance and a durable design to minimize service. Your IT staff will appreciate the backwards compatibility, since it allows for these printers to be up and running with minimal time and effort.
The ZT200 series has been designed for ease of use, versatility and outstanding value.
  • Space-saving design
    Compact footprint and streamlined design fits easily in confined areas where space is at a premium. Space saving design with unique bi-fold door fits easily into tight spaces maximizing work space.
  • Fast installation and integration
    Icon-based status LEDs provide immediate and easily visible printer status.
  • Intuitive, effortless media loading
    Side-loading design eliminates complicated threading of supplies. Color-coded cues give even first-time users visual guidance for loading ribbon and media. Illuminated moveable sensor is visible through the media for trouble-free sensor-position adjustment
  • Print quality
    Engineered for greater print precision with finetuned adjustments. Crisp, clean text and barcodes - even on narrow media.
  • Zebra reliability and durability
    Built for light industrial and commercial environments. Drive system designed for optimal performance, with minimal maintenance required.
  • Simplified serviceability
    Easy, tool-less platen and printhead removal enable simple cleaning and replacement. Simple interchangeable connectivity options enable rapid printer changes and upgrade. Only three common tools needed for basic service.
Zebra ZT230 - label printer - monochrome - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
9.1 kg
United Kingdom, Europe
Max Media Size
Roll (11.4 cm)
Min Media Size (Custom)
19.4 mm
Max Media Size (Custom)
114 mm x 991 mm
Print Speed
Up to 152 mm/sec - B/W - Roll (11.4 cm)
Max Resolution (B&W)
203 dpi
USB, LAN, serial
400 MHz
RAM Installed (Max)
128 MB SDRAM
Flash Memory Installed (Max)
128 MB
Language Simulation
ZPL, ZPL II, EPL, Extensible Mark-up Language (XML)
Barcodes
Code 93, Industrial 2 of 5, Code 39, Code 49, CODABLOCK, ISBT 128, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, Data Matrix, PLANET, TLC39, Plessey, Code 128B, Code 128C, Code 128A, Standard 2 of 5
Media Type
Labels, continuous paper labels, die cut labels
Print server - Ethernet, Fast Ethernet
Printer Features
Zebra Programming Language (ZPL) support, XML-enabled printing, Multi-level Element Energy Equalizer (E3)
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
1 year warranty
24.2 cm x 43.2 cm x 27.7 cm
Printer Type
Printer
Print Speed
Up to 152 mm/sec - B/W - 203 dpi - Roll (11.4 cm)
Built-in Devices
Status LCD
Wired
USB, LAN, serial
203 dpi
Language Simulation
Fonts Included
1 x scalable , 7 x bitmapped
Barcodes
Printer Features
400 MHz
RAM
RAM Installed (Max)
128 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
128 MB
Media Handling
Media Type
Max Media Size
Roll (11.4 cm)
19.4 mm
114 mm x 991 mm
Media Sizes
Roll (1.94 - 11.4 cm)
Max Printing Width
104 mm
Max Printing Length
3988 mm
Media Thickness Range
0.076 mm - 0.25 mm
Roll Maximum Outer Diameter
203 mm
Roll Core Diameter
76 mm, 25 mm
Media Feeders
1 x manual - 1 roll - Roll (11.4 cm)
Print server
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB , 1 x LAN
VCCI, C-Tick, BSMI, EN 61000-3-2, ICES-003, NOM, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class B, FCC Part 15 B, CCC, KCC, GOST-R, S Mark, cTUVus, UkrSEPRO
Power supply - internal
AC 120/230 V
Frequency Required
47 - 63 Hz
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
5 °C
20 - 85% (non-condensing)
24.2 cm
43.2 cm
27.7 cm
9.1 kg
Weight (Shipping)
11.4 kg
Type: Printer
Max Print Speed: [N/A]
Brand: Zebra
Price Range Ex VAT: 500 - 750
