Zebra incorporated extensive customer feedback, as well as the legacy of the industry leading Stripe and S4M printers, to create the ZT200 Series family of printers with elegant space saving design, effortless setup, intuitive user operation, and ease of service and maintenance.
ZT220 industrial printer offers a high impact polymer case and simple single-use three button interface for simpler applications.
- Zebra ZT220 - label printer - B/W - thermal transfer
- Printer Type
- Label printer - thermal transfer - B/W
- 7.8 kg
- Localisation
- United Kingdom, Europe
- Max Media Size
- Roll (11.4 cm)
- Min Media Size (Custom)
- 19.4 mm
- Max Media Size (Custom)
- 114 mm x 991 mm
- Print Speed
- Up to 152 mm/sec - B/W - Roll (11.4 cm)
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB, LAN, serial
- Processor
- 400 MHz
- RAM Installed (Max)
- 128 MB SDRAM
- Flash Memory Installed (Max)
- 128 MB
- Language Simulation
- ZPL, ZPL II, Extensible Mark-up Language (XML)
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, Code 49, CODABLOCK, ISBT 128, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, Data Matrix, PLANET, TLC39, Plessey, Code 128B, Code 128C, Code 128A, Standard 2 of 5
- Media Type
- Labels, continuous paper labels, die cut labels
- Tear bar
- Networking
- Print server - Ethernet, Fast Ethernet
- Printer Features
- Zebra Programming Language (ZPL) support, XML-enabled printing, Multi-level Element Energy Equalizer (E3)
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 23.9 cm x 43.2 cm x 28 cm
- Printer Type
- Label printer - thermal transfer - monochrome
- Localisation
Printer
- Print Speed
- Up to 152 mm/sec - B/W - 203 dpi - Roll (11.4 cm)
- Built-in Devices
- Status LCD, tear bar
- Connectivity Technology
- Wired
- Interface
- USB, LAN, serial
- 203 dpi
- Tear bar
- Fonts Included
- 1 x scalable , 7 x bitmapped
- Barcodes
- Printer Features
- Processor
- 400 MHz
RAM
- 128 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 128 MB
Media Handling
- Media Type
- Max Media Size
- Roll (11.4 cm)
- 19.4 mm
- 114 mm x 991 mm
- Media Sizes
- Roll (1.94 - 11.4 cm)
- Max Printing Width
- 104 mm
- Max Printing Length
- 3988 mm
- Media Thickness Range
- 0.076 mm - 0.25 mm
- Roll Maximum Outer Diameter
- 203 mm
- Roll Core Diameter
- 76 mm, 25 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (11.4 cm)
- Networking
- Print server
- Network Controller Name
- ZebraNet 10/100 Print Server
- Data Link Protocol
- Connections
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB , 1 x LAN
- LED indicator
- VCCI, C-Tick, BSMI, EN 61000-3-2, ICES-003, NOM, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class B, FCC Part 15 B, CCC, KCC, GOST-R, S Mark, cTUVus, UkrSEPRO
- Power Device
- Power supply - internal
- Frequency Required
- 47 - 63 Hz
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 20 - 85% (non-condensing)
- 23.9 cm
- 43.2 cm
- 28 cm
- 7.8 kg
- Weight (Shipping)
- 11.4 kg
|  | Zebra ZT200 SERIES INTERNAL ZEBRANET - P1037974-001 | In Stock | £261.07 |
