Brand
Zebra Z-Select 2000D Permanent Adhesive Labels
Quicklinx: 99T1WS00 Mfr#: 3007209-T
Type: Labels
Technology: [N/A]
18 in stock
£115.91 ex VAT
£139.09 inc VAT
A white smooth coated direct thermal label that produces black visible light images at speeds of up to 152mm per second on all Zebra industrial and desktop printers. The permanent rubber-based adhesive will adhere to most surfaces, and can be used at temperatures as low as -40°C. Ideal for packaging and labeling promotional products and chilled or frozen products.
Zebra Z-Select 2000D - labels - 11160 label(s) - 57 x 76 mm
Labels
Adhesive Type
Permanent adhesive
Media Size
57 x 76 mm
Printing Technology
Direct thermal
Card / Label Qty per Sheet/Roll
930
Qty of Media with Cards
12 roll(s)
Included Qty
11160 label(s)
Compatible with
LP 2824; TLP 2824, 2844; Zebra GX420d, GX420t; GK Series GK420t; G-Series GC420t; GX Series GX420, GX430, GX430t; H 2824-Z; LP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z; TLP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z, 3842, 3844-Z
Media
Media Type
Labels
Adhesive Type
Permanent adhesive
Media Sizes
57 x 76 mm
Printing Technology
Direct thermal
930
12 roll(s)
Included Qty
11160 label(s)
Compatible with
Eltron LP 2824 , Eltron TLP 2824, 2844 , Zebra GX420d, GX420t , Zebra GK Series GK420t , Zebra G-Series GC420t , Zebra GX Series GX420, GX430, GX430t , Zebra H 2824-Z , Zebra LP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z , Zebra TLP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z, 3842, 3844-Z
Type: Labels
Technology: [N/A]
Brand: Zebra
Stock Status: In stock
