Zebra Z-Select 2000D 57x32mm
Quicklinx: 84J9WS00 Mfr#: 800262-125
Type: Labels
Technology: Direct Thermal
Hurry, only 1 left in stock!
£107.55 ex VAT
£129.06 inc VAT
Direct Quick Print 3000 is a premium, smooth, bright white, direct thermal, paper labelstock. The thermally-sensitive top coating increases the battery life of your Zebra mobile printers, ensuring maximum printhead life. Its all-temperature, permanent adhesive provides premium cold temperature performance and adhesion to a variety of surfaces.
Zebra Z-Select 2000D - labels - 25200 label(s) - 57.2 x 31.8 mm
Labels
Product Material
Paper
Adhesive Type
Permanent adhesive
Perforation
Perforated
Media Size
57.2 x 31.8 mm
Printing Technology
Direct thermal
Card / Label Qty per Sheet/Roll
2100
Qty of Media with Cards
12 roll(s)
Included Qty
25200 label(s)
Compatible with
LP 2622, 2642, 2722, 2742, 2824, 2844, 3642, 3742; Orion; TLP 2622, 2642, 2722, 2742, 2824, 2844, 3642, 3742; Zebra DA402, GX420; GK Series GK420; G-Series GC420; GX Series GX420, GX430; H 2824; LP 2722, 2742, 2824, 2844; TLP 2722, 2742, 2824, 2844, 3742, 3842, 3844
Media
Media Type
Labels
Product Material
Paper
Adhesive Type
Permanent adhesive
Perforation
Perforated
Media Sizes
57.2 x 31.8 mm
Printing Technology
Direct thermal
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm
2100
12 roll(s)
Included Qty
25200 label(s)
Perforation between labels
Compatible with
Eltron LP 2622, 2642, 2722, 2742, 2824, 2844, 3642, 3742 , Eltron Orion , Eltron TLP 2622, 2642, 2722, 2742, 2824, 2844, 3642, 3742 , Zebra DA402, GX420d, GX420t , Zebra GK Series GK420t , Zebra G-Series GC420t , Zebra GX Series GX420, GX430, GX430t , Zebra H 2824-Z , Zebra LP 2722, 2742, 2824, 2824 Plus, 2824-Z, 2844, 2844-Z , Zebra TLP 2722, 2742, 2824, 2824 Plus, 2824-Z, 2844, 2844-Z, 3742, 3842, 3844-Z
Type: Labels
Brand: Zebra
