Zebra Z-Perform 1000D - 880191-038D Economy direct thermal paper l
Quicklinx: 7Z4DWS00 Mfr#: 88019-1038d
Type: [N/A]
Hurry, only 1 left in stock!
£144.90 ex VAT
£173.88 inc VAT
Z-Perform 1000D is an uncoated direct thermal paper facestock that offers a low-cost solution for general-purpose industrial applications up to 3 inches per second. With its permanent acrylic adhesive and consistent quality, it is an excellent option for compliance labeling, product labeling, shelf labeling, and work-in-process labeling and is recommended for short-term applications that do not require durability against moisture or tough environmental conditions including heat, humidity, or U.V. light.
Zebra Z-Perform 1000D - labels - 21480 label(s) - 102 x 38 mm
Labels
Product Material
Paper
Adhesive Type
Permanent adhesive
Coating
Uncoated
Media Size
102 x 38 mm
Printing Technology
Direct thermal
Card / Label Qty per Sheet/Roll
1790
Qty of Media with Cards
12 roll(s)
Included Qty
21480 label(s)
Compatible with
LP 2824; TLP 2824, 2844; Zebra GX420d, GX420t; GK Series GK420t; G-Series GC420t; GX Series GX420, GX430, GX430t; LP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z; TLP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z, 3842, 3844-Z
Media
Media Type
Labels
Product Material
Paper
Adhesive Type
Permanent adhesive
Coating
Uncoated
Media Sizes
102 x 38 mm
Printing Technology
Direct thermal
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25 mm
1790
12 roll(s)
Included Qty
21480 label(s)
Compatible with
Eltron LP 2824 , Eltron TLP 2824, 2844 , Zebra GX420d, GX420t , Zebra GK Series GK420t , Zebra G-Series GC420t , Zebra GX Series GX420, GX430, GX430t , Zebra LP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z , Zebra TLP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z, 3842, 3844-Z
Type: [N/A]
Brand: Zebra
