Zebra YMCKO 5 Panel 330 Images
Quicklinx: 7089WS00 Mfr#: 800015-540
Type: Print Ribbon
Technology: Thermal transfer
£59.04 ex VAT
£70.84 inc VAT
TrueColors Multi-Panel Ribbons utilize heat to initiate a process called dye sublimation transfer, in which the color dye on the ribbon is vaporized into a gas and infused onto the card at the printhead station. Several types of ribbon panel combinations are available (some use a clear protective overcoat (O) panel which is applied to the entire card as the final printing step to protect the card image).
The 5 Panel ribbon (YMCKO) is designed for full color printing on one or both sides of a card.
Zebra TrueColours - black, yellow, cyan, magenta, transparent - print ribbon
Print ribbon
Printing Technology
Dye sublimation
Printing Colour
Black, yellow, cyan, magenta, transparent
Yield
Up to 330 images
Compatible with
Zebra P310i, P320i, P330i, P420i, P430i, P520i
Consumable
Consumable Type
Print ribbon
Printing Technology
Dye sublimation
Yield
Up to 330 images
Compatible with
Type: Print Ribbon
Brand: Zebra
