Zebra YMCKO 5 Panel 200 Images
Quicklinx: 71LVWS00 Mfr#: 800015-440
TrueColors Multi-Panel Ribbons utilize heat to initiate a process called dye sublimation transfer, in which the color dye on the ribbon is vaporized into a gas and infused onto the card at the printhead station. Several types of ribbon panel combinations are available (some use a clear protective overcoat (O) panel which is applied to the entire card as the final printing step to protect the card image).
The 5 Panel ribbon (YMCKO) is designed for full color printing on one or both sides of a card.
Zebra TrueColours - black, yellow, cyan, magenta, transparent - print ribbon
Print ribbon
Printing Technology
Dye sublimation
Printing Colour
Black, yellow, cyan, magenta, transparent
Yield
Up to 200 images
Compatible with
P 310i; Zebra P310i, P330i, P430i
Consumable
Consumable Type
Print ribbon
Printing Technology
Dye sublimation
Yield
Up to 200 images
Compatible with
Eltron P 310i , Zebra P310i, P330i, P430i
