For consistent high-quality output from your Zebra card printer, use Zebra's TrueColours print ribbon. TrueColours ribbon delivers vibrant color photos and "true-to-life" flesh tones, as well as sharp monochrome bar codes and text.
Prolong card life with Zebra's patented overlay ("O panel") in the ribbon, which protects your card against dye migration and abrasions. TrueColours ribbon is also designed to help extend the life your Zebra card printer with a unique silicone-based coating that minimizes printhead debris. Ribbon without this coating allows particulate buildup on the print head, which may decrease the life of this critical printer part.
- Zebra TrueColours i Series YMCKO Eco Cartridge - 1 - YMCKO - print ribbon cassette
- Product Type
- Print ribbon cassette
- Printing Technology
- Dye sublimation
- Printing Colour
- Colour (yellow, magenta, cyan, black, overlay)
- Yield
- Up to 200 images
- Included Qty
- 1
- Compatible with
- Zebra P100i, P110i, P110i QuikCard ID Solution, P110m, P120i, P120i QuikCard ID Solution
Consumable
- Consumable Type
- Dye sublimation
- Included Qty
- 1
- Yield
- Up to 200 images
- Consumables Included
- 1 x cleaning roller
- Compatible with
