Zebra TLP2824 PLUS RS232/USB
Quicklinx: B3HLWS00 Mfr#: 282P-101120-000
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal / thermal transfer
£281.35 ex VAT
£337.62 inc VAT
At 2.2", the direct thermal and thermal transfer TLP 2824 bar code label printer is ideal for retail and other label applications. The TLP 2824 redefines the compact printer class. It fits into areas other printers cannot, withstanding rough handling and integrating easily into a wide range of applications. A 5" media roll capacity and clear media window optimize productivity, while a maximum print speed of 4" per second enables fast job processing.
The TLP 2824 excels in delivering printing solutions for business and professional offices, including retail point of sale, shelf labeling, product marking, healthcare specimen labeling and patient tracking, inventory and asset management, small office or home office mailing, shipping, and file folder labeling.
  • A powerful, ultra-compact printer
    One of the smallest in its class, the easy-to-use 2824 Plus desktop printer tucks into your tightest work spaces and prints 2-inch-wide labels or receipts with best-in-class print speeds. The 2824 Plus includes Zebra setup utilities, which guides you through simple setup steps so you can get up and running quickly. It also includes an OpenACCESS design and clear media window for simple media loading and monitoring.
  • Better performance, more flexibility
    A robust 32-bit RISC processor increases throughput and productivity with faster formatting and first label out. For greater flexibility and enhanced performance, choose from a variety of options like convenient peeler and cutter, and 64 MB Flash memory that lets you store and use more graphics and fonts. With co-resident EPL and ZPL programming languages, the 2824 Plus works seamlessly with other Zebra printers, while serial/parallel/USB connectivity and optional 10/100 Ethernet allow easy system integration.
Zebra TLP 2824 Plus - label printer - B/W - thermal transfer
Printer Type
Label printer - thermal transfer - B/W
1.6 kg
Max Media Size
Roll (6 cm)
Max Media Size (Custom)
60 mm
Print Speed
Up to 102 mm/sec - max speed
Max Resolution (B&W)
203 dpi
USB, serial
RAM Installed (Max)
8 MB
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL II, EPL2, EPL
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A, GS1 DataBar Omnidirectional
Media Type
Labels, continuous forms, perforated thermal paper, receipt paper, fanfold paper, tag stock
Microsoft Certification
Compatible with Windows 7
13.5 cm x 24.1 cm x 17.8 cm
Printer Type
Label printer - thermal transfer - monochrome
Printer
Print Speed
Up to 102 mm/sec - max speed - 203 dpi
Wired
USB, serial
203 dpi
Language Simulation
ZPL II, EPL2, EPL
Barcodes
RAM
RAM Installed (Max)
8 MB
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (6 cm)
60 mm
Media Sizes
Roll (6 cm)
Max Printing Width
56 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.18 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38 mm
Media Feeders
1 x manual - 1 roll - Roll (6 cm)
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
UL, VCCI, C-Tick, NOM, FCC, IRAM
Power adapter - external
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities, ZebraDesigner
5 °C
41 °C
10 - 90%
13.5 cm
24.1 cm
17.8 cm
1.6 kg
B3HL Zebra Z-Select 2000D 57x32mm In Stock £107.64
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (6 cm)
Brand: Zebra
