Developed specifically to meet the unique needs of healthcare providers, Zebra's reliable HC100 Patient I.D. Solution makes wristband printing easier and more cost-effective than laser solutions. This solution combines the reliable HC100 direct thermal printer with easy-to-load cartridges containing the industry's only antimicrobial-coated wristbands-Zebra's Z-Band® wristbands. Minimal training! Pop the wristband cartridge into the HC100 printer-print individual wristbands on demand. Compare these two simple steps with laser printing, which often requires staff to load forms into a special tray, print labels, apply a label to the band, and fold a laminate over the band. The HC100 printer detects wristband size-adult, pediatric, infant-and automatically calibrates its settings for optimal print quality.
Features Quick & easy media cartridge loading 300 dpi print resolution (12 dots/mm) Prints at 2 inches/second Direct thermal printing of bar codes, text, and graphics Dual-wall frame, impact resistant plastic Zebra E3TM Printhead Energy Control Illuminated Media Low/Media Out indicator Tool-less printhead and platen replacement Instant media calibration-no wasted media Standard tear-off mode feature XML-Enabled printing-allows XML communications from information systems ZPL® or ZPL II® programming language
