Zebra S4M TT  ZPL  300 DPI  Z-NET
Quicklinx: 82Z2WS00 Mfr#: S4M00-300E-0700T
Zebra's S4M printer packages ease of use, metal construction, and a variety of connectivity options into a thermal printer that takes a full 8" roll of Zebra labels for fewer media changes. Designed for the budget-minded, the S4M has the features needed to support many applications at an affordable price. With easy controls and proven side-loading design, it's quick to learn, use, and load, so operators can focus on more productive tasks. Compared to similar printers on the market, the S4M thermal printer is an outstanding value.
  • Versatile connectivity
    Equipped with a serial interface, the Zebra S4M label printer offers flexible connectivity options, making it easy to integrate into existing systems.
  • Wide range of barcode support
    The printer's ability to print a variety of barcodes, including CODABLOCK, Codabar, and QR code, among others, ensures compatibility with diverse industry standards.
  • Robust media handling
    With a roll core diameter of 76 mm and a maximum outer diameter of 203 mm, alongside a media thickness range of 0.076 mm to 0.25 mm, this printer is designed to accommodate a wide range of media sizes and types.
  • High-speed printing
    Achieve productivity with a printing speed of up to 152 mm/s, allowing for efficient label production.
  • Compliance with standards
    Meets various compliance standards including EN 61000-3-2 and EN55024, ensuring reliability and quality in diverse environments.
Zebra S4M - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
12.4 kg
Max Media Size
Roll (11.4 cm)
Min Media Size (Custom)
19.4 mm
Max Media Size (Custom)
114 mm x 991 mm
Print Speed
Up to 152 mm/sec - B/W
Max Resolution (B&W)
300 dpi
Parallel, USB, LAN, serial
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL, ZPL II, EPL2, EPL
Barcodes
Code 93, Industrial 2 of 5, Code 39, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, MSI-Plessey, Data Matrix, PLANET, TLC39, Plessey, Code 128B, Code 128C, Code 128A, Standard 2 of 5
Media Type
Labels, continuous forms, tag stock, die cut labels
Fonts
CG Triumvirate Bold Condensed
Print server - Ethernet, Fast Ethernet
Microsoft Certification
Compatible with Windows 7
27.2 cm x 47.7 cm x 29.5 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Printer
Print Speed
Up to 152 mm/sec - B/W - 203 dpi
Built-in Devices
Status LCD
Wired
300 dpi
Language Simulation
Fonts
Fonts Included
7 x bitmapped , 1 x scalable
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (11.4 cm)
19.4 mm
114 mm x 991 mm
Media Sizes
Roll (11.4 cm), Roll (1.94 cm)
Max Printing Width
104 mm
Max Printing Length
1854 mm
Media Thickness Range
0.076 mm - 0.25 mm
Roll Maximum Outer Diameter
203 mm
Roll Core Diameter
76 mm, 25 mm
Media Feeders
1 x manual - 1 roll - Roll (11.4 cm)
Print server
Network Controller Name
ZebraNet 10/100 Print Server
1 x RS-232 , 1 x USB , 1 x parallel , 1 x LAN - RJ-45
FCC Class B certified, VCCI, C-Tick, EN 61000-3-2, ICES-003, NOM, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class B, CCC, IRAM, cULus, GOST-R
Power supply - internal
Frequency Required
50/60 Hz
Power Factor Correction
Software Included
ZebraDesigner, ZebraDesigner Pro, ZebraDesigner for XML, ZebraNet Bridge Enterprise, Zebra Universal Driver, ZBI-Developer, ZebraNet Utilities 7.0
20 - 85% (non-condensing)
27.2 cm
47.7 cm
29.5 cm
12.4 kg
Weight (Shipping)
15.2 kg
