Zebra S4M Mono Label Printer
Quicklinx: 4S6DWS00 Mfr#: S4M00200E0100T
Zebra's S4M printer packages ease of use, metal construction, and a variety of connectivity options into a thermal printer that takes a full 8" roll of Zebra labels for fewer media changes. Designed for the budget-minded, the S4M has the features needed to support many applications at an affordable price. With easy controls and proven side-loading design, it's quick to learn, use, and load, so operators can focus on more productive tasks. Compared to similar printers on the market, the S4M thermal printer is an outstanding value.
  • Versatile connectivity
    Equipped with a serial interface, the Zebra S4M label printer offers flexible connectivity options, making it easy to integrate into existing systems.
  • Wide range of barcode support
    The printer's ability to print a variety of barcodes, including CODABLOCK, Codabar, and QR code, among others, ensures compatibility with diverse industry standards.
  • Robust media handling
    With a roll core diameter of 76 mm and a maximum outer diameter of 203 mm, alongside a media thickness range of 0.076 mm to 0.25 mm, this printer is designed to accommodate a wide range of media sizes and types.
  • High-speed printing
    Achieve productivity with a printing speed of up to 152 mm/s, allowing for efficient label production.
  • Compliance with standards
    Meets various compliance standards including EN 61000-3-2 and EN55024, ensuring reliability and quality in diverse environments.
Zebra S4M - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
12.4 kg
Max Media Size
Roll (11.4 cm)
Max Media Size (Custom)
114 mm
Print Speed
Up to 152 mm/sec - B/W
Max Resolution (B&W)
203 dpi
Parallel, USB, serial
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL, ZPL II
Barcodes
Code 93, Industrial 2 of 5, Code 39, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, Interleaved 2 of 5, Postnet, MSI-Plessey, Data Matrix, PLANET, TLC39, Plessey
Media Type
Labels, continuous forms
Microsoft Certification
Works with Windows Vista
27.2 cm x 47.7 cm x 29.5 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Printer
Print Speed
Up to 152 mm/sec - B/W - 203 dpi
Built-in Devices
Status LCD
Wired
203 dpi
Language Simulation
ZPL, ZPL II
Fonts Included
7 x bitmapped , 1 x scalable
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (11.4 cm)
114 mm
Media Sizes
Roll (11.4 cm), Roll (2 cm)
Max Printing Width
104 mm
Media Thickness Range
0.076 mm - 0.25 mm
Roll Maximum Outer Diameter
203 mm
Roll Core Diameter
76 mm, 25.4 mm
Media Feeders
1 x manual - 1 roll - Roll (11.4 cm)
1 x USB , 1 x RS-232 , 1 x parallel
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, EN 60950, EN 61000-3-2, ICES-003, IEC950, NOM, EN 61000-3-3, EN55024, CSA 22.2 No. 950, EN55022 Class B, CCC, MIC
Power supply - internal
Frequency Required
50/60 Hz
5 °C
20 - 85%
27.2 cm
47.7 cm
29.5 cm
12.4 kg
4S6D Zebra 3200 Wax/Resin - Print ink ribbon refill (thermal transfer) - 1 x black - 110 mm x 450 m In Stock £125.99
Resources
The following resources are available for the Zebra S4M Mono Label Printer
