Zebra's QL family of direct thermal mobile printers has built a highly satisfied following through its proven drop-resistant durability; user-friendly, productivity-boosting features; and easy integration. Zebra's third generation of QL printers, the QLn series - including the QLn220 for 2-inch-wide printing - extends these QL-platform benefits to the "nth" power.
Even more durable, the QLn220 heightens productivity through an easier-to-navigate display; faster, higher-quality printing; a variety of proactive alerts, and many convenient charging accessories. It's also easier to integrate, with Zebra Global Printing, improved network performance, and ZebraLink support - including remote, Ethernet-connected diagnosis and management of printers, batteries, configuration and firmware for greater printer uptime and operations productivity. The QLn220 is ideal for healthcare applications such as bedside specimen and pharmacy labeling.
- Zebra QLn 220 - Healthcare - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- Form Factor
- Portable
- 570 g
- Max Media Size
- Roll (5.5 cm)
- Min Media Size (Custom)
- 16 mm
- Max Media Size (Custom)
- 55.4 mm
- Print Speed
- Up to 102 mm/sec - max speed
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB, serial, Wi-Fi(n), Bluetooth 3.0
- Processor
- 400 MHz
- RAM Installed (Max)
- 128 MB
- Flash Memory Installed (Max)
- 256 MB
- Language Simulation
- ZPL, EPL, Comtec Printer Control Language (CPCL)
- Barcodes
- Code 93, Code 39, UCC/EAN-128, NW-7, GS1 DataBar, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, FIM, TLC39
- Media Type
- Labels, continuous forms, receipt paper, linerless labels
- Fonts
- CG Triumvirate Bold Condensed
- Fixed gap/bar media sensor, realtime clock, Black Mark sensor, tear bar
- Display Resolution
- 240 x 128
- Keyboard
- 7 keys
- Printer Features
- Antimicrobial casing
- Battery
- Required 1 Lithium Ion Included Qty 1
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 8.9 cm x 16.5 cm x 7 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Up to 102 mm/sec - max speed - 203 dpi
- Built-in Devices
- Status LCD, tear bar
- Connectivity Technology
- Wireless
- Interface
- 203 dpi
- Fonts
- 240 x 128
- Keyboard
- 7 keys
- Fonts Included
- 25 x bitmapped , 1 x scalable
- Barcodes
- Printer Features
- Processor
- 400 MHz
RAM
- 128 MB
Flash Memory
- Flash Memory
- 256 MB
Media Handling
- Media Type
- Max Media Size
- Roll (5.5 cm)
- 16 mm
- 55.4 mm
- Media Sizes
- Roll (1.6 - 5.5 cm)
- Max Printing Width
- 48 mm
- Max Printing Length
- 813 mm
- Roll Maximum Outer Diameter
- 55.9 mm
- Roll Core Diameter
- 19 mm, 34.9 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (5.5 cm)
- Connections
- 1 x USB , 1 x RS-232 - 14 pin DIN
- Water-resistant, dust-resistant, drop-resistant, built-in battery charger
- CSA, UL, TUV, EN 60950, EN55024, EN55022 Class B, FCC Part 15 B, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-5, EN55024 Class B, IEC 60529 IP43, VCCI Class B
- Lithium Ion
- Required Qty
- 1
- Included
- 1
- Capacity
- 2450 mAh
- Software Included
- Drivers & Utilities, Link-OS
- Limited warranty - 1 year , Limited warranty - printhead - 6 months
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- 8.9 cm
- 16.5 cm
- 7 cm
- 570 g
