Zebra P110i Single Sided Network Thermal Card Printer
Quicklinx: 65Y7WS00 Mfr#: P110I-000UC-ID0
Reliable, compact and easy to use, the P110i is Zebra's most affordable color card printer. The sleek design uses high strength plastics and advanced electronics for reduced size and weight and outstanding performance, all at a great price. The P110i delivers consistent, high quality printing and trusted Zebra dependability.
  • Efficient printing speed
    Capable of producing 120 cards per hour, this printer ensures your workflow remains uninterrupted, providing quick turnaround times for all your printing needs.
  • High-quality output
    With a maximum resolution of 300 DPI, the Zebra P110i delivers sharp, vivid color prints, ensuring that every card looks professional.
  • Versatile media handling
    Supports a wide range of barcode formats including Code 39, EAN/JAN, and UPC-A, alongside PVC card and card media types, making it a flexible solution for various printing requirements.
  • Reliable connectivity
    Equipped with a USB interface, this printer offers a reliable, wired connection to your systems, ensuring consistent performance without the worry of connectivity issues.
  • Durable design
    Built to operate within a wide range of environmental conditions and compliant with UL and cUL standards, the Zebra P110i is designed for durability and reliability in various settings.
Zebra P110i - plastic card printer - colour - dye sublimation/thermal resin
Printer Type
Plastic card printer - dye sublimation/thermal resin - colour
4.3 kg
United States, Europe
Max Media Size
CR-80 Card (85.6 x 54 mm)
Max Media Size (Custom)
54 mm x 86 mm
Print Speed
Up to 120 cards/hour - colour single-sided - 54 x 86 mm
Max Resolution (Colour)
300 dpi
USB, LAN
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, Code 128, Code 2 of 5, Interleaved 2 of 5, PDF417
Media Type
Cards, PVC card
Total Media Capacity
100 cards
Print server - Ethernet, Fast Ethernet
Microsoft Windows 2000 / XP
1-year warranty
20.1 cm x 32.8 cm x 21.6 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN
300 dpi
Barcodes
Media Handling
Media Type
Cards, PVC card
Max Media Size
54 mm x 86 mm
Card / Label Sizes
CR-80 Card (85.6 x 54 mm), 54 x 86 mm
100 cards
Media Feeders
1 x automatic - 100 cards - CR-80 Card (85.6 x 54 mm)
Print server
1 x USB , 1 x LAN - RJ-45
FCC Class B certified, UL, cUL
Power supply - internal
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities
Limited warranty - 1 year
15 °C
30 °C
20 - 65%
20.1 cm
32.8 cm
21.6 cm
4.3 kg
65Y7 Zebra Premier Card - 54mm x 86mm - 500 x Card In Stock £28.90
