Zebra MZ320 Bluetooth Mobile Printer
Quicklinx: 5BHJWS00 Mfr#: M3E-0UB0E060-00
Get the benefits and value associated with Zebra with MZ 320 economical receipt printers. Each tiny MZ printer can be a smart assistant for mobile receipt printing applications where you need quick, simple receipts on demand. Use 802.11g, Bluetooth, or IrDA to connect to a handheld or smart phone device and produce crisp, clear receipts!
These unobtrusive printers weigh 3/4 of a pound, so they can be worn comfortably for a full shift without interfering with the user's tasks. Stylish and compact, they're ideal for customer-facing applications where an industrial-looking printer just won't do. Its features and functions are intuitive and easy to operate as well. And because it's a Zebra, there's no compromise in reliability when you choose an MZ 320 entry-level printer.
  • Versatile barcode support
    Equipped to handle a wide array of barcode formats including Aztec code, Codabar, Code 128, and QR code, the Zebra MZ 320 offers comprehensive scanning capabilities suitable for various industry needs.
  • Durable design
    Designed to withstand the rigors of daily use, the Zebra MZ 320 operates efficiently in a temperature range from -10°C to 50°C, ensuring reliable performance in diverse working environments.
  • Efficient battery life
    Powered by a 1500 mAh lithium-ion battery, this printer is built for extended use, minimizing downtime and maximizing productivity on-the-go.
  • Wireless connectivity
    With IrDA interface and wireless readiness, the Zebra MZ 320 offers flexible connectivity options, facilitating easy integration into existing systems and mobile operations.
  • High-quality printing
    Achieves a maximum resolution of 203 DPI for monochrome printing, ensuring clear and legible labels every time, with a maximum printing speed of 76 mm/s for efficient label production.
Zebra MZ 320 - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
Portable
340 g
United Kingdom
Max Media Size
Roll (7.6cm)
Max Media Size (Custom)
76.2 mm x 813 mm
Print Speed
Up to 76 mm/sec - B/W
Max Resolution (B&W)
203 dpi
USB, Bluetooth, IrDA
RAM Installed (Max)
8 MB
Flash Memory Installed (Max)
4 MB
Language Simulation
Card Printer Program Language (CPPL)
Barcodes
Code 93, Code 39, UCC/EAN-128, NW-7, GS1 DataBar, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, FIM, Codablock F, GS1 DataBar-14
Media Type
Labels, continuous forms, receipt paper
Print server - Bluetooth
Required 1 Lithium Ion Included Qty 1
Microsoft Windows 2000, Microsoft Pocket PC, Microsoft Windows NT, Microsoft Windows XP, Microsoft Windows Mobile for Pocket PC 2002, Microsoft Windows CE .NET, Microsoft Windows Mobile for Pocket PC 2003 Second Edition
Microsoft Certification
Works with Windows Vista
10.4 cm x 5.7 cm x 13.6 cm
Printer Type
Label printer - direct thermal - monochrome
United Kingdom
Printer
Print Speed
Up to 76 mm/sec - B/W - 203 dpi
Wireless
203 dpi
Language Simulation
Barcodes
RAM
RAM Installed (Max)
8 MB
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (7.6cm)
76.2 mm x 813 mm
Media Sizes
Roll (7.6cm)
Max Printing Width
73.7 mm
Roll Maximum Outer Diameter
47.8 cm
Roll Core Diameter
19 mm
Media Feeders
1 x manual - 1 roll - Roll (7.6cm)
Print server
Bluetooth
1 x USB , 1 x IrDA - IrDA
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
VCCI, C-Tick, BSMI, EN55022, NOM, IEC 60950, FCC Part 15 B, CCC, IC, MIC, RoHS
Power adapter - external
Lithium Ion
Required Qty
1
Included
1
1500 mAh
-10 °C
50 °C
10 - 90%
10.4 cm
5.7 cm
13.6 cm
340 g
Resources
The following resources are available for the Zebra MZ320 Bluetooth Mobile Printer
