Zebra MC92N0-G Data Collection Terminal 2GB 3.7" - Win Embedded Compact 7
Quicklinx: CL09WS00 Mfr#: MC92N0-GA0SXAYA5WR
The MC9200 rugged mobile computer, the next generation of the industry-leading gold standard for mobility, has evolved to meet changing business needs, bringing you the same signature rugged design, best-in-class barcode scanning and dependable operation. Now, with the power to run applications with highly-intuitive interfaces, the MC9200 will further simplify processes and increase worker productivity in your toughest environments.
The power you need to support any application
A dual core 1 GHz processor, 2GB of Flash memory, up to 32GB of additional SD memory and Microsoft's advanced mobile operating systems provide provide the power to run complex ERP applications — simultaneously.
High-speed 802.11a/b/g/n Wi-Fi
Support for the fastest Wi-Fi connection available today — 802.11n — provides your workers with the best possible wireless voice and data experience.
Proven rugged construction, ready for your most challenging environments
Every day, the MC9000 Series devices deliver reliable performance, despite everyday drops on concrete, subzero cold, extreme heat, dust, spills and more.
Government-grade security
Government-grade FIPS 140-2 Level 1 certification secures Wi-Fi and Bluetooth wireless communications, without impacting device or application performance.
Six advanced scan engines — the most scan engine options
No matter what type of bar codes are in use in your facility, there is a scan engine option that is optimized for rapid-fire capture of 1D, 2D, driver’s license, DPM codes and more — even if the codes are dirty, damaged or poorly printed.
Six interchangeable keypads for superior customization
Choose the keypad that makes data entry as easy as possible for any type of application.
  • Proven rugged construction, ready for your most challenging environments
    Every day, the MC9200 Series devices deliver reliable performance, despite everyday drops on concrete, subzero cold, extreme heat, dust, spills and more.
  • Government-grade security
  • Six interchangeable keypads for superior customization
Zebra MC92N0-G - data collection terminal - Win Embedded Compact 7 - 2 GB - 3.7"
Data collection terminal - rugged
Operating System
Microsoft Windows Embedded Compact 7
Display
3.7" colour TFT - 640 x 480
OMAP4430 OMAP4430 (Dual-Core)
Processor Clock Speed
1 GHz
Storage
2 GB
RAM
512 MB
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Wireless Connectivity
802.11a/b/g/n, Bluetooth 2.1 EDR
Barcode Reader
Yes (laser)
9.1 cm x 19.3 cm x 23.1 cm
765 g
1-year warranty
Operating System
Display
3.7" colour TFT
Resolution
640 x 480
Colour Depth
64K colours (16-bit)
OMAP4430 OMAP4430
1 GHz
Number of Cores
Dual-Core
Storage
2 GB
RAM
512 MB
Max Supported Capacity
32 GB
Communications
Security Protocols & Features
LEAP, TLS, WPA2, 802.1x, AES
Multimedia
Audio
Microphone, speaker
Input Device
Touch-screen, keypad
Keys Qty
28
Barcodes
Barcode Reader
Scan Element Type
Laser
Expansion and Connectivity
Expansion Slots
1 x SDHC Memory Card
Lithium Ion
2200 mAh
Pistol grip handle
EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, FCC Part 15, RoHS, FIPS 140-2, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, MIL-STD 810G, IEC 60825-1, FCC Part 15.407, CCX V4, EN 50371, CSA C22.2 No. 60950-1, EN 60825-1, IEC 60529 IP64, EN 62311, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-17
9.1 cm
19.3 cm
23.1 cm
765 g
Limited warranty - 1 year
-20 °C
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
CL09 Zebra MC9X 2600 Mah Lithium Ion Handheld Battery In Stock £69.01
