The innovative LS 2208 hand-held scanner from Symbol Technologies delivers performance features at an affordable price to make your buying decision easier than ever. If you're seeking investment protection and great value in a small, light scanner that assures maximum productivity, then the LS 2208 is the ideal scanner for you.
From the checkout line to the back room, the LS 2208 helps you make the most of your application-specific solution in a variety of ways.
Getting started with the LS 2208 is fast and simple with 123Scan setup utility. This easy-to-use tool reduces startup time and costs wherever the scanner is used. To further save you money, the scan element in the LS 2208 is based on a liquid injection process that delivers integral shock protection, providing durability you can count on. These powerful features enable you to reduce downtime and keep maintenance costs to a minimum.
In any industry, the high-value LS 2208 hand-held scanner offers superior performance, excellent reliability and user-friendly ergonomics to create a more productive mobile environment. And when you choose the LS 2208, you receive the added assurance of purchasing from Symbol - a company with proven solutions and millions of scanner installations worldwide.
Durable single-board construction
Meets stringent 5-ft drop tests. -
Scratch-resistant tempered glass exit window
Is designed for continuous use. -
Accurate first-time capture of 1D bar codes
Increased productivity, resulting in shorter check-out lines and better customer service. -
Wide working range
Delivers optimal performance from contact to 17 in (43 cm). -
Multiple onboard interfaces
Simplify installation and integration and ensures future compatibility. -
Plug-and-Play, with universal cable
Means rapid deployment, with a single cable connecting to any computing environment. -
Intuitive design
Minimizes setup and training time. -
Ergonomic, lightweight design
Reduces user fatigue with sleek, balanced form for maximum comfort and productivity. -
Advanced Data Formatting (ADF)
Enables users to modify data prior to sending to host computer, reducing costly modifications to the host software.
- Symbol LS2208 - barcode scanner
- Barcode scanner - handheld - USB
- Cash register white
- Scan Element Type
- Visible laser diode
- Scan Speed
- 100 scan / sec
- Connectivity Technology
- Wired
- 6.3 cm x 8.4 cm x 15.2 cm
- 146 g
- 5-year warranty
Barcode
- Interface Type
- USB
- Scan Element Type
- Light Source Wave Length
- 650 nm
- Scan Mode
- Single-pass
- Scan Speed
- 100 scan / sec
- Max Working Distance
- 43 cm
- Skew (Degrees)
- 60
- Pitch (Degrees)
- 65
- Print Contrast Signal (PCS)
- 20%
- Decode Capability
- Code 93, Code 39, UCC/EAN-128, IATA, Code 39 Full ASCII, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, Code 128 Full ASCII, Code 39 Trioptic
- Wired
- OK Notification
- Beeper, LED indicator
- Advanced Data Formatting (ADF)
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable
- VCCI, ICES-003 Class B, FCC Part 15 B, MITI, EMC, RoHS
- Power Device
- Power adapter
- 6.3 cm
- 8.4 cm
- 15.2 cm
- 146 g
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 5 - 95%
- Drop Specification
- 1.5 m to concrete
