Zebra LP2844 UK
Zebra LP2844 UK
Quicklinx: 457XWS00 Mfr#: 2844-20320-0001
Leading the way in versatile and affordable desktop printing. The direct thermal LP 2844 bar code printer brings a new level of performance to the Zebra desktop family. This space-saving, user-friendly printer delivers optimal performance in today's on-demand desktop labeling applications. The LP 2844 is loaded with impressive features and a small price tag!
  • Efficient connectivity
    Equipped with a serial interface, this label printer ensures reliable wired connectivity for seamless integration into existing systems.
  • High-quality printing
    With a maximum resolution of 203 DPI, the Zebra LP 2844 delivers clear and crisp monochrome outputs, making it ideal for label printing.
  • Rapid output
    Achieve a maximum printing speed of 102 mm/s, enabling fast production of labels to meet the demands of busy work environments.
Zebra LP 2844 - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.4 kg
Max Media Size
Roll (10.8cm)
Max Media Size (Custom)
108 mm
Print Speed
Up to 102 mm/sec - B/W
Max Resolution (B&W)
203 dpi
Parallel, USB, serial
RAM Installed (Max)
256 KB (512 KB) - SDRAM
Flash Memory Installed (Max)
512 KB (1 MB)
Language Simulation
EPL2
Barcodes
Code 93, Code 39, UCC/EAN-128, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, GS1 DataBar-14, Plessey, MacroPDF417
Media Type
Labels, continuous forms, name tags cards, fanfold paper
Microsoft Windows NT 4.0, Microsoft Windows 95/98/ME/2000/XP
Microsoft Certification
Works with Windows Vista
20.1 cm x 23.8 cm x 17 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Up to 102 mm/sec - B/W - 203 dpi
Wired
203 dpi
Language Simulation
EPL2
Fonts Included
5 x bitmapped
Barcodes
RAM
RAM Installed (Max)
256 KB / 512 KB (max)
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
512 KB (installed) / 1 MB (max)
Media Handling
Media Type
Max Media Size
Roll (10.8cm)
108 mm
Media Sizes
Roll (10.8cm)
Max Printing Width
104 mm
Media Thickness Range
0.075 mm - 0.18 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38 mm
Media Feeders
1 x manual - 1 roll - Roll (10.8cm)
1 x USB - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics , 1 x RS-232 - 9 pin D-Sub (DB-9)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
CSA, UL, VCCI, C-Tick, BSMI, GOST, NOM, CCC, FCC
Power adapter - external
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities
5 °C
41 °C
10 - 90%
20.1 cm
23.8 cm
17 cm
1.4 kg
Resources
The following resources are available for the Zebra LP2844 UK
