The ultra-compact direct thermal LP 2824 Plus bar code label printer brings powerful performance to applications requiring a space-saving printer and media widths of 2.2 inches/56 mm or less. It includes a 32-bit RISC processor for faster formatting and first label out, an auto-sensing serial port, and co-resident EPL and ZPL programming languages.
The LP 2824 Plus is easy to use with an OpenAccess design and clear media window for simple media loading and monitoring, color-coded user-guide touch points, and instant reset button. Serial, Parallel, and USB interfaces, plus networking option, ensure easy system integration for a wide range of applications.
A powerful, ultra-compact printer
One of the smallest in its class, the easy-to-use 2824 Plus desktop printer tucks into your tightest work spaces and prints 2-inch-wide labels or receipts with best-in-class print speeds. The 2824 Plus includes Zebra setup utilities, which guides you through simple setup steps so you can get up and running quickly. It also includes an OpenAccess design and clear media window for simple media loading and monitoring. -
Better performance, more flexibility
A robust 32-bit RISC processor increases throughput and productivity with faster formatting and first label out. For greater flexibility and enhanced performance, choose from a variety of options like convenient peeler and cutter, and massive flash memory that lets you store and use more graphics and fonts. With co-resident EPL and ZPL programming languages, the 2824 Plus works seamlessly with other Zebra printers, while Serial/Parallel/USB connectivity allows easy system integration.
- Zebra LP 2824 Plus - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.2 kg
- Max Media Size
- Roll (6 cm)
- Max Media Size (Custom)
- 60 mm
- Print Speed
- Up to 102 mm/sec - max speed
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB, serial
- RAM Installed (Max)
- 8 MB
- Flash Memory Installed (Max)
- 4 MB
- Language Simulation
- ZPL, ZPL II, EPL2, EPL
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, Code 128B, Code 128C, German Post, MSI-3, Code 128A, GS1 DataBar Omnidirectional
- Media Type
- Labels, continuous forms, perforated thermal paper, receipt paper, linerless labels, fanfold paper, tag stock
- Microsoft Certification
- Compatible with Windows 7
- 11.1 cm x 21.6 cm x 17.1 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Up to 102 mm/sec - max speed - 203 dpi
- Connectivity Technology
- Wired
- Interface
- USB, serial
- 203 dpi
- Barcodes
RAM
- 8 MB
Flash Memory
- Flash Memory
- 4 MB
Media Handling
- Media Type
- Max Media Size
- Roll (6 cm)
- 60 mm
- Media Sizes
- Roll (6 cm)
- Max Printing Width
- 56 mm
- Max Printing Length
- 991 mm
- Media Thickness Range
- 0.08 mm - 0.18 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm, 38 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (6 cm)
- Connections
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
- UL, VCCI, C-Tick, NOM, FCC, IRAM
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities, ZebraDesigner
- 5 °C
- 41 °C
- 10 - 90%
- 11.1 cm
- 21.6 cm
- 17.1 cm
- 1.2 kg
- Weight (Shipping)
- 2.4 kg
