Zebra Internal ZebraNet 10/100 PrintServer
Quicklinx: 80PWWS00 Mfr#: G47480
How do you make the best thermal bar code printers even better? With the ZebraNet Print Server Family. Look to the top-of-the-line ZebraNet 10/100 Print Server to deliver more value to your Zebra printing network by leveraging existing network resources to significantly speed data transmission. The ZebraNet 10/100 Print Server increases the networking capabilities of some of Zebra's most powerful bar code printers. And, if you require 10Base-T and 100Base-T networking, Zebra printers with the ZebraNet 10/100 Print Server can support both - providing the flexibility you need.
ZebraNet 10/100 Print Server - print server - 10/100 Ethernet
Print server
Internal
Ports
10/100 Ethernet
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Network / Transport Protocol
TCP/IP
IEEE 802.2, IEEE 802.3
S Series 105SL; Xi Series 110XiIIIPlus, 140XillIPlus, 170XiIIIPlus, 220XiIIIPlus, R110XiIIIPlus, R170XiIIIPlus
Print server
Internal
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
TCP/IP
Remote Management Protocol
SNMP 1, Telnet, IPP, HTTP
1 x 100Base-TX - RJ-45
Compatible Slots
1 x Expansion Slot
RoHS
25 - 85%
Zebra S Series 105SL , Zebra Xi Series 110XiIIIPlus, 140XillIPlus, 170XiIIIPlus, 220XiIIIPlus, R110XiIIIPlus, R170XiIIIPlus
