Zebra HC100 Monochrome Direct Thermal Label Printer
Quicklinx: 8Y16WS00 Mfr#: HC100-300E-1100
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
Hurry, only 1 left in stock!
£503.93 ex VAT
£604.71 inc VAT
Zebra's complete and integrated wristband solution combines the small-footprint HC100 thermal printer with easy-to load cartridges containing Zebra's patent pending antimicrobial - Z-band direct wristbands. Its smart technology senses the wristband type and auto calibrates the settings for optimized print quality.
The design of the HC100 provides easy-to-use features that require minimal, if any, user interaction. There is minimal training required to use the HC100 or to load or switch the cartridge - it's a quick and simple task.
The HC100 printer is designed for wristband printing. Administrators can quickly process patient admissions without having to change the media in the printer. It also eliminates waste by printing only the required number of wristbands.
Zebra HC100 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.4 kg
United Kingdom, Europe
Max Media Size
Roll (3.02 cm)
Print Speed
Up to 102 mm/sec - max speed - Roll (3.02 cm)
Max Resolution (B&W)
300 dpi
USB, LAN, serial
RAM Installed (Max)
16 MB SDRAM
Flash Memory Installed (Max)
8 MB
Language Simulation
ZPL, ZPL II, Extensible Mark-up Language (XML)
Barcodes
Code 93, Industrial 2 of 5, Code 39, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Plessey
Media Type
Wristband labels
Print server - Ethernet, Fast Ethernet - internal
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
12.7 cm x 24.2 cm x 17.8 cm
Printer Type
Printer
Print Speed
Wired
USB, LAN, serial
300 dpi
Language Simulation
Fonts Included
16 x bitmapped , 1 x scalable
Barcodes
RAM
RAM Installed (Max)
16 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
8 MB
Media Handling
Media Type
Wristband labels
Max Media Size
Roll (3.02 cm)
Media Sizes
Roll (3.02 cm), Roll (2.54 cm), Roll (1.91 cm)
Max Printing Length
558 mm
Media Feeders
1 x manual - 1 roll - Roll (3.02 cm)
Print server - internal
Network Controller Name
ZebraNet 10/100 Print Server
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
TUV, VCCI, C-Tick, EN55024, EN55022 Class B, CB, FCC Part 15 B, IEC 60950-1, IEC 60601-1
Power adapter - external
AC 120/230 V
Frequency Required
50/60 Hz
Power Factor Correction
Software Included
Drivers & Utilities, ZebraDesigner, ZebraNet Utilities 7.0
Environmental Standards
ENERGY STAR
4 °C
20 - 85% (non-condensing)
12.7 cm
24.2 cm
17.8 cm
1.4 kg
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (3.02 cm)
Brand: Zebra
Price Range Ex VAT: 500 - 750
