Zebra's GX420d printer pairs fast print speeds with a large set of features. Innovative label, receipt and tag-handling capabilities enable the flexibility you need. Offering top print quality and a variety of connectivity options, the GX420d supports the widest range of applications and can be integrated into almost any environment so that you can improve efficiency and profitability, save time and reduce operator training.
- Zebra GX420d - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.4 kg
- Max Media Size
- Roll (10.8cm)
- Min Media Size (Custom)
- 19 mm x 9.7 mm
- Max Media Size (Custom)
- 108 mm x 991 mm
- Print Speed
- Up to 152 mm/sec - B/W - Roll (10.8cm)
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB, LAN, serial
- RAM Installed (Max)
- 8 MB SDRAM
- Flash Memory Installed (Max)
- 4 MB
- Language Simulation
- ZPL, ZPL II, EPL2
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A
- Media Type
- Labels, continuous forms, receipt paper, fanfold paper, tag stock
- Networking
- Print server - Ethernet, Fast Ethernet
- Microsoft Certification
- Works with Windows Vista
- 17.1 cm x 20.9 cm x 15.2 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN, serial
- 203 dpi
- ZPL, ZPL II, EPL2
- Fonts Included
- 1 x bitmapped , 1 x scalable
- Barcodes
RAM
- 8 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 4 MB
Media Handling
- Media Type
- Max Media Size
- Roll (10.8cm)
- 19 mm x 9.7 mm
- 108 mm x 991 mm
- Media Sizes
- Roll (10.8cm)
- Max Printing Width
- 104 mm
- Max Printing Length
- 991 mm
- Media Thickness Range
- 0.08 mm - 0.2 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm, 38 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (10.8cm)
- Networking
- Print server
- Network Controller Name
- ZebraNet 10/100 Print Server
- Data Link Protocol
- Connections
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB , 1 x LAN - RJ-45
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- TUV, VCCI, C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- Power Factor Correction
- 5 °C
- 41 °C
- 10 - 90% (non-condensing)
- 17.1 cm
- 20.9 cm
- 15.2 cm
- 1.4 kg
Ink (2)
Zebra GK420-GX420 Print Head Assembly Direct Thermal- 20 | In Stock | £104.02 |
Zebra Z-Select 2000D 57x32mm | In Stock | £107.02 |
Other bundles (2)
Zebra 3200 Premium Wax/Resin (12 Pack) - Black | In Stock | £28.94 |
Zebra Z-Perform 1000D - 880191-038D Economy direct thermal paper l | In Stock | £143.30 |
