Zebra GX Series GX420d  Monochrome Direct Thermal Label Printer
Quicklinx: DD5KWS00 Mfr#: GX42-202420-000
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Roll (10.8cm)
£414.64 ex VAT
£497.56 inc VAT
Zebra's GX420d printer pairs fast print speeds with a large set of features. Innovative label, receipt and tag-handling capabilities enable the flexibility you need. Offering top print quality and a variety of connectivity options, the GX420d supports the widest range of applications and can be integrated into almost any environment so that you can improve efficiency and profitability, save time and reduce operator training.
Zebra GX420d - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.4 kg
Max Media Size
Roll (10.8cm)
Min Media Size (Custom)
19 mm x 9.7 mm
Max Media Size (Custom)
108 mm x 991 mm
Print Speed
Up to 152 mm/sec - B/W - Roll (10.8cm)
Max Resolution (B&W)
203 dpi
USB, LAN, serial
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL, ZPL II, EPL2
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A
Media Type
Labels, continuous forms, receipt paper, fanfold paper, tag stock
Print server - Ethernet, Fast Ethernet
Microsoft Certification
Works with Windows Vista
17.1 cm x 20.9 cm x 15.2 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Wired
USB, LAN, serial
203 dpi
Language Simulation
ZPL, ZPL II, EPL2
Fonts Included
1 x bitmapped , 1 x scalable
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (10.8cm)
19 mm x 9.7 mm
108 mm x 991 mm
Media Sizes
Roll (10.8cm)
Max Printing Width
104 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.2 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38 mm
Media Feeders
1 x manual - 1 roll - Roll (10.8cm)
Print server
Network Controller Name
ZebraNet 10/100 Print Server
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB , 1 x LAN - RJ-45
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
TUV, VCCI, C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15
Power adapter - external
Frequency Required
50/60 Hz
Power Factor Correction
5 °C
41 °C
10 - 90% (non-condensing)
17.1 cm
20.9 cm
15.2 cm
1.4 kg
Ink (2)
DD5K Zebra Z-Select 2000D 57x32mm In Stock £107.55
DD5K Zebra Z-Select 2000D Permanent Adhesive Labels In Stock £112.93
Other bundles (2)
DD5K Zebra 3200 Premium Wax/Resin (12 Pack) - Black In Stock £29.46
DD5K Zebra Z-Perform 1000D - 880191-038D Economy direct thermal paper l In Stock £143.86
Type: Printer
Brand: Zebra
