Zebra's feature-rich, competitively priced GC420t desktop printer brings performance and reliability to many low- to medium-volume, thermal transfer printing applications. The printer's space-saving design contains a powerful 32-bit processor for fast label throughput; a large memory for more graphics storage, longer label formats, and faster processing. It also includes both EPL and powerful ZPL programming languages - making it easy to integrate with other Zebra printers - while its triple connectivity option offers system integration flexibility. The GC420t delivers all the quality, durability and value you expect from Zebra.
- Zebra G-Series GC420t - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 1.5 kg
- Localisation
- United Kingdom, Europe
- Max Media Size
- Roll (10.8cm)
- Min Media Size (Custom)
- 25 mm
- Max Media Size (Custom)
- 991 mm
- Print Speed
- Up to 102 mm/sec - max speed
- Interface
- Parallel, USB, serial
- RAM Installed (Max)
- 8 MB SDRAM
- Flash Memory Installed (Max)
- 8 MB
- Language Simulation
- ZPL, ZPL II, EPL2, EPL
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Plessey, MacroPDF417, EAN-14, Code 128B, Code 128C, MSI-3, Code 128A, Standard 2 of 5
- Media Type
- Labels, fanfold paper, tag stock
- Microsoft Certification
- Compatible with Windows 7
- 20.1 cm x 23.9 cm x 17.3 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
- Localisation
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- Barcodes
RAM
- 8 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 8 MB
Media Handling
- Media Type
- Max Media Size
- Roll (10.8cm)
- 25 mm
- 991 mm
- Max Printing Width
- 104 mm
- Max Printing Length
- 991 mm
- Media Thickness Range
- 0.08 mm - 0.18 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm, 38 mm
- Media Feeders
- 1 x manual - 1 roll
- Connections
- 1 x USB , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x parallel
- FCC Class B certified, TUV, NOM, KCC
- Frequency Required
- 50 - 60 Hz
- 5 °C
- 41 °C
- 10 - 90% (non-condensing)
- 20.1 cm
- 23.9 cm
- 17.3 cm
- 1.5 kg
Ink (8)
Zebra RIBBON WAX 2300 110MM X 74M(Box of 12) | In Stock | £33.67 |
Zebra 1ROLL ZSLCT 2000D 102 X 64 MM 12 rolls | In Stock | £174.05 |
Zebra Z-PERF 1000D 80 RECEIPT 102MM 100 METERS C-25MM BOX OF 12 | In Stock | £94.53 |
Zebra Z-Select 2000D 57x32mm | In Stock | £108.31 |
Zebra 12 ROLLS Z-SLCT 2000D 51X25MM | In Stock | £102.29 |
Zebra Z-Select 2000D Permanent Adhesive Labels | In Stock | £112.27 |
Zebra Ribbon Wax/Resin 110mm x 74m | In Stock | £50.78 |
Zebra Direct 1100 Perforated Matte Permanent Rubber Adhesive Paper - 16440 pcs. | In Stock | £115.65 |
Other bundles (2)
Zebra Z-Perform 1000D - 880191-038D Economy direct thermal paper l | In Stock | £145.02 |
Zebra Z ONECARE SEL >30 DAYS PURCHAS | In Stock | £319.24 |
