Zebra GC420 Desktop Printer
Quicklinx: 8HXRWS00 Mfr#: GC420-200520-000
Zebra's feature-rich, competitively priced GC420d desktop printer brings performance and reliability to many low- to medium-volume, direct thermal printing applications. The printer's space-saving design contains a powerful 32-bit processor for fast label throughput; a large memory for more graphics storage, longer label formats, and faster processing. It also includes both EPL and powerful ZPL programming languages - making it easy to integrate with other Zebra printers - while its triple connectivity option offers system integration flexibility. The GC420d delivers all the quality, durability and value you expect from Zebra.
  • Versatile barcode support
    Equipped to handle a wide array of barcodes including Aztec code, CODABLOCK, Data Matrix, and QR code, the Zebra G-Series GC420d ensures compatibility with various standards, making it a flexible solution for diverse business needs.
  • Robust connectivity options
    With its USB interface, the Zebra G-Series GC420d offers reliable wired connectivity, ensuring seamless integration into existing systems without complex setup procedures.
  • Efficient media handling
    The printer accommodates rolls up to 10.8 cm in size and supports a media thickness range of 0.08 mm to 0.18 mm, allowing for versatile media handling capabilities for different printing needs.
  • High-quality printing output
    Leveraging direct thermal printing technology, the GC420d delivers monochrome printing output at a maximum speed of 102 mm/s, combining efficiency with quality to meet business demands.
  • Durable design
    Certified by FCC Class B, KCC, NOM, and TUV, the Zebra G-Series GC420d is built to withstand the rigors of various operating environments, from 5°C to 41°C, ensuring reliable performance where it matters most.
Zebra G-Series GC420d - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.5 kg
Max Media Size
Roll (10.8cm)
Min Media Size (Custom)
25 mm
Max Media Size (Custom)
991 mm
Print Speed
Up to 102 mm/sec - max speed
Parallel, USB, serial
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
8 MB
Language Simulation
ZPL, ZPL II, EPL2, EPL
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Plessey, MacroPDF417, EAN-14, Code 128B, Code 128C, MSI-3, Code 128A, Standard 2 of 5
Media Type
Labels, fanfold paper, tag stock
Microsoft Certification
Compatible with Windows 7
20.1 cm x 23.9 cm x 17.3 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Wired
Language Simulation
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
8 MB
Media Handling
Media Type
Max Media Size
Roll (10.8cm)
25 mm
991 mm
Max Printing Width
104 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.18 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38 mm
Media Feeders
1 x manual - 1 roll
1 x USB , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x parallel
FCC Class B certified, TUV, NOM, KCC
Frequency Required
50 - 60 Hz
5 °C
41 °C
10 - 90% (non-condensing)
20.1 cm
23.9 cm
17.3 cm
1.5 kg
