Zebra G-Series GX430t Thermal Transfer Desptop Printer
Quicklinx: BML3WS00 Mfr#: GX43-102421-000
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Technology: Thermal transfer
Max Paper Size: Roll (10.8cm)
£526.71 ex VAT
£632.05 inc VAT
This direct thermal/thermal transfer desktop printer includes a 300dpi print head to ensure high-quality, crisp, clear printing of 2-D bar codes, fine text and complex graphics -ideal for high-density data on small labels. It has the widest range of features and the easiest ribbon-loading system of any desktop printer on the market. It prints up to 4 inches per second.
  • Versatile barcode compatibility
    Supports a wide range of barcodes including Aztec code, Codabar, and QR code, making it ideal for diverse industry applications from retail to healthcare.
  • High-quality printing
    Delivers sharp, clear prints with a maximum resolution of 300 DPI, ensuring every detail is captured for accurate barcode scanning.
  • Efficient media handling
    Accommodates rolls up to 10.8 cm with a core diameter of 25.4 mm and a maximum outer diameter of 127 mm, facilitating seamless label printing operations.
  • Robust connectivity options
    Equipped with USB and serial interfaces, offering flexible connection solutions to easily integrate into existing systems.
  • Durable design for demanding environments
    Built to operate within a wide temperature range from 5°C, ensuring reliable performance in various working conditions.
Zebra GX Series GX430t - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
2.1 kg
United Kingdom, Europe
Max Media Size
Roll (10.8cm)
Min Media Size (Custom)
19 mm x 9.7 mm
Max Media Size (Custom)
108 mm x 991 mm
Print Speed
Up to 102 mm/sec - max speed
Max Resolution (B&W)
300 dpi
USB, LAN, serial
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB (68 MB)
Language Simulation
ZPL, ZPL II, EPL2
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, Plessey, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A
Media Type
Labels, continuous forms, fanfold paper, tag stock
Peeler
Print server - Ethernet, Fast Ethernet
Microsoft Certification
Compatible with Windows 7
1-year warranty
19.4 cm x 25.4 cm x 19.1 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Printer
Print Speed
Up to 102 mm/sec - max speed - 300 dpi
Built-in Devices
Status LCD, peeler
Wired
USB, LAN, serial
300 dpi
Language Simulation
ZPL, ZPL II, EPL2
Peeler
Fonts Included
16 x bitmapped , 1 x scalable
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB (installed) / 68 MB (max)
Media Handling
Media Type
Max Media Size
Roll (10.8cm)
19 mm x 9.7 mm
108 mm x 991 mm
Media Sizes
Roll (1.9 - 10.8 cm)
Max Printing Width
104 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.2 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 12.7 mm, 37.1 mm
Media Feeders
1 x manual - 1 roll - Roll (10.8cm)
Print server
Network Controller Name
ZebraNet 10/100 Print Server
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
Peeler
1 x USB cable
TUV, VCCI, C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15
Power adapter - external
Frequency Required
50/60 Hz
Power Factor Correction
Software Included
Drivers & Utilities, ZebraDesigner
Limited warranty - 1 year
5 °C
41 °C
10 - 90% (non-condensing)
19.4 cm
25.4 cm
19.1 cm
2.1 kg
Weight (Shipping)
4.1 kg
Ink (3)
BML3 Zebra RIBBON WAX 2300 110MM X 74M(Box of 12) In Stock £33.20
BML3 Zebra Z-Select 2000D 57x32mm In Stock £108.24
BML3 Zebra Ribbon Wax/Resin 110mm x 74m In Stock £50.10
Other bundles (2)
BML3 Zebra 3200 Premium Wax/Resin (12 Pack) - Black In Stock £29.29
BML3 Zebra Z-Perform 1000D - 880191-038D Economy direct thermal paper l In Stock £144.93
Type: Printer
Brand: Zebra
Price Range Ex VAT: £500 - £750
