Zebra G-Series GK420t Mono Direct Thermal Label Printer
Quicklinx: 815VWS00 Mfr#: GK42-102220-000
With the GK420t direct thermal/thermal transfer printer, use Zebra's easy ribbon-loading thermal transfer technology to produce crisp, long lasting label images, or direct thermal technology to print receipts and labels for indoor, short-term use. The GK420t is well-suited to any industry, and provides the same print speeds and connectivity options as the GK420d.
Zebra GK Series GK420t - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
2.1 kg
Europe
Max Media Size
Roll (10.8cm)
Min Media Size (Custom)
19 mm x 9.7 mm
Max Media Size (Custom)
108 mm
Print Speed
Up to 127 mm/sec - max speed
Max Resolution (B&W)
203 dpi
USB, LAN
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL, ZPL II, EPL2
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A
Media Type
Labels, continuous forms, tag stock
Print server - Ethernet, Fast Ethernet
Microsoft Certification
Compatible with Windows 7
19.4 cm x 25.4 cm x 19.1 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Europe
Printer
Print Speed
Wired
USB, LAN
203 dpi
Language Simulation
ZPL, ZPL II, EPL2
Fonts Included
1 x bitmapped , 1 x scalable
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (10.8cm)
19 mm x 9.7 mm
108 mm
Media Sizes
Roll (10.8cm)
Max Printing Width
104 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.2 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38 mm
Media Feeders
1 x manual
Print server
Network Controller Name
ZebraNet 10/100 Print Server
1 x USB , 1 x LAN - RJ-45
TUV, VCCI, C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15
Power adapter - external
Frequency Required
50/60 Hz
Power Factor Correction
5 °C
41 °C
10 - 90% (non-condensing)
19.4 cm
25.4 cm
19.1 cm
2.1 kg
Weight (Shipping)
4.1 kg
Ink (7)
815V Zebra RIBBON WAX 2300 110MM X 74M(Box of 12) In Stock £33.36
815V Zebra 1ROLL ZSLCT 2000D 102 X 64 MM 12 rolls In Stock £188.55
815V Zebra Z-Select 2000D 57x32mm In Stock £117.31
815V Zebra 12 ROLLS Z-SLCT 2000D 51X25MM In Stock £110.47
815V Zebra Z-Select 2000D Permanent Adhesive Labels In Stock £114.60
815V Zebra Ribbon Wax/Resin 110mm x 74m In Stock £50.32
815V Zebra Direct 1100 Perforated Matte Permanent Rubber Adhesive Paper - 16440 pcs. In Stock £125.22
Other bundles (2)
815V Zebra 3200 Premium Wax/Resin (12 Pack) - Black In Stock £29.42
815V Zebra Z-Perform 1000D - 880191-038D Economy direct thermal paper l In Stock £157.19
