Zebra G-Series GK420d Mono Direct Thermal Label Printer
Quicklinx: 7WB6WS00 Mfr#: GK42-202220-000
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
£334.71 ex VAT
£401.65 inc VAT
The Zebra GK420d direct thermal printer offers the best value in a basic desktop printer, featuring a fast 5 inches per second print speed to meet your low to medium volume printing requirements. The GK420d has a sleek and compact design, boasts the smallest footprint in a 4-inch desktop printer, and supports a variety of applications and industries.
The GK420d comes standard with EPL and ZPL programming languages, and dual connectivity (USB, serial) for easy integration into existing systems. For additional flexibility, 10/100 internal Ethernet is also available. Well-suited to any industry, the reliable GK420d desktop printer is a smart investment that's always a perfect fit.
Zebra GK Series GK420d - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.4 kg
Max Media Size
Roll (10.8cm)
Min Media Size (Custom)
19 mm x 9.7 mm
Max Media Size (Custom)
108 mm x 991 mm
Print Speed
Up to 127 mm/sec - B/W - Roll (10.8cm)
Max Resolution (B&W)
203 dpi
USB, LAN
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL, ZPL II, EPL2
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A
Media Type
Continuous forms, fanfold paper, tag stock
Print server - Ethernet, Fast Ethernet
Microsoft Certification
Works with Windows Vista
17.1 cm x 20.9 cm x 15.2 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Wired
USB, LAN
203 dpi
Language Simulation
ZPL, ZPL II, EPL2
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (10.8cm)
19 mm x 9.7 mm
108 mm x 991 mm
Media Sizes
Roll (10.8cm)
Max Printing Width
104 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.2 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38 mm
Media Feeders
1 x manual - 1 roll
Print server
Network Controller Name
ZebraNet 10/100 Print Server
1 x LAN - RJ-45 , 1 x USB
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
TUV, VCCI, C-Tick, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15
Frequency Required
50/60 Hz
Power Factor Correction
5 °C
41 °C
10 - 90% (non-condensing)
17.1 cm
20.9 cm
15.2 cm
1.4 kg
7WB6 Zebra GK420-GX420 Print Head Assembly Direct Thermal- 20 In Stock £104.02
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (10.8cm)
Brand: Zebra
