Zebra DS9208 Digital Omnidirectional Hands-Free Barcode Scanner
Quicklinx: 8W0MWS00 Mfr#: DS9208-SR4NNU21ZE
Whether you need to scan printed bar codes on paper labels or mobile bar codes on the screen of a mobile phone, with the Motorola DS9208, you'll be ready. You get the versatility to scan any 1D or 2D bar code - from the printed labels in retail that identify product and pricing at the register to mobile coupons, mobile gift and loyalty cards, boarding passes and even theater tickets. And the DS9208 provides all the features you need to keep your workers productive: industry-leading scanning speed; true point-and-shoot scanning simplicity - no need to align bar code and scanner; and hands-free and handheld flexibility.
  • Affordable scanning technology for mobile world
    Whether you need to scan printed bar codes on paper labels or mobile bar codes on the screen of a mobile phone, with the Zebra DS9208, you'll be ready. You get the versatility to scan any 1D or 2D bar code - from the printed labels in retail that identify product and pricing at the register to mobile coupons, mobile gift and loyalty cards, boarding passes and even theater tickets. And the DS9208 provides all the features you need to keep your workers productive: industry-leading scanning speed; true point-and-shoot scanning simplicity - no need to align bar code and scanner; and hands-free and handheld flexibility.
  • Boost customer service, loyalty and revenues with mobile bar codes
    Convenience is driving your customers to store boarding passes, event tickets, mobile gift and loyalty cards as well as mobile coupons on their cell phones, where they are always available and easy to find - unlike their physical counterparts. But if you can't scan the mobile bar codes, convenience turns into a hassle that could result in a lost customer. With the DS9208, you are ready to complete the mobile bar code transaction chain, able to scan virtually any mobile bar code on any type of display - protecting service levels and customer loyalty.
  • A 'go anywhere' design and tiny footprint
    Maybe your retail store has a trendy decor. Or maybe your counter space is extremely limited. The DS9208 sports a sleek contemporary design that is at home in either environment. And with the most compact footprint in this class, the DS9208 can fit in the most space constrained areas - from the POS in a boutique to the ticket window at a train station.
  • A smart investment and a low Total Cost of Ownership (TCO)
    The DS9208 not only helps you make money, it helps you save money. The device is so intuitive that training - and training-related costs - are virtually eliminated. Right out of the box, the DS9208 can read the most common 1D and 2D bar codes on a wide variety of surfaces - from paper labels to cell phone displays. Integrated Electronic Article Surveillance (EAS) functionality eliminates the need to purchase and manage a standalone EAS system.
Zebra DS9208 Omnidirectional Hands-Free Presentation Imager - barcode scanner
Barcode scanner - desktop - USB - decoded
Midnight black
EMEA
Minimum Bar Width
4 mil
Scan Element Type
2D imager
Scan Speed
2300 mm / sec
Wired
8.2 cm x 8 cm x 14 cm
284 g
3-year warranty
Midnight black
EMEA
Barcode
Interface Type
USB
Minimum Bar Width
4 mil
Scan Element Type
2D imager
Light Source Wave Length
630 nm
Scan Mode
Single-pass
Scan Speed
2300 mm / sec
Max Working Distance
26.7 cm
Skew (Degrees)
60
Pitch (Degrees)
65
Decode Capability
Code 93, Matrix 2 of 5, Code 39, UCC/EAN-128, ISBT 128, NW-7, ISBN, GS1 DataBar, QR code, MaxiCode, Aztec code, Bookland, Code 32, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Discrete 2 of 5, MicroPDF417, Italy Pharmacode, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, TLC39, Australian Post, Japanese Post, Kix (Netherlands) Post, IATA 2 of 5, UPC-E1, UPC-A/EAN-13 with Extended Coupon Code, EAN-UCC Composite, MacroPDF417, ISSN, Code 128 Full ASCII, Code 39 Trioptic, UK Post, Royal Mail, Micro QR code, 4-State postal code, CC-A, CC-B, CC-C, GS1 DataBar Omnidirectional, GS1 DataBar Expanded, GS1 DataBar Expanded Stacked, GS1 DataBar Limited
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Reduced Space Symbology (RSS)
1 x USB cable
VCCI, EN55022, EN55024, CISPR 22, ICES-003 Class B, RoHS, Laser Class 2, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60825-1, FCC CFR47 Part 15 B, IEC 60529 IP50, CSA C22.2 No. 60950-1, EN 60825-1
Software
Software Included
Drivers & Utilities
8.2 cm
8 cm
14 cm
284 g
Limited warranty - 3 years
5 - 85% (non-condensing)
Drop Specification
1.5 m to concrete
