Zebra DS8108-SR Scanner Bundle - Scanner/Cable/Stand
Quicklinx: DKHMWS00 Mfr#: DS8108-SR7U2100SGW
Type: Barcode scanner
Form Factor: Handheld
£202.83 ex VAT
£243.39 inc VAT
Combining the power of advanced microprocessor, a high-resolution megapixel sensor and Zebra's exclusive PRZM Intelligent Imaging technology, the premium DS8108 delivers the very best in scanning performance to increase transactions and reduce customer wait time in the busy, scan-intensive environments. Innovative features let you go beyond just capturing barcodes.
  • Efficient barcode scanning
    The Zebra DS8108-SR barcode scanner utilizes PRZM Intelligent Imaging technology to handle various barcode types including QR codes and Data Matrix, ensuring smooth operation in any setting.
  • Robust construction
    Built to withstand the rigors of everyday use, this scanner is compliant with IP42 standards, offering protection against dust and splashes, suitable for diverse work environments.
  • Wide operational range
    This device functions effectively across a temperature range of 0 °C to 50 °C and can operate within a humidity spectrum of 5% to 95%, enabling it to perform in various conditions.
  • User-friendly notifications
    The DS8108-SR features both an LED indicator and beeper for operational confirmations, allowing users to know when a scan has been successfully completed.
  • Durable design
    With a drop specification of 1.8 m to concrete, this handheld barcode scanner is designed to endure shocks and vibrations, ensuring longevity and reliability in demanding environments.
Zebra DS8108-SR - Standard Range (SR) - barcode scanner
Barcode scanner - handheld - USB - decoded
Twilight black
Minimum Bar Width
3 mil
Scan Element Type
2D imager
Sensor Resolution
1280 x 960
Wired
6.6 cm x 10.7 cm x 16.8 cm
154 g
5-year warranty
Twilight black
Barcode
Interface Type
USB
Minimum Bar Width
3 mil
Scan Element Type
2D imager
Sensor Resolution
1280 x 960
Light Source Wave Length
617 nm
Scan Mode
Single-pass
Skew (Degrees)
60
Pitch (Degrees)
60
Print Contrast Signal (PCS)
16%
Decode Capability
Code 39, QR code, Code 128, Data Matrix
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Clock Speed
800 MHz
1 x USB
Cradle
1 x USB cable
EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, RoHS, FIPS 140-2, UL 60950-1, CAN/CSA C22.2 No. 60950-1-07, IP42, EN 50581, IEC 62471, EN 55032 Class B, ICES-003 issue 6 Class B, EN60950-1 (2nd Edition) + A11 + A1 + A12 + A2:2013, EN60950-1 (2nd Edition) + A1 + A2
Electric Current Required
450 mA (operating)
6.6 cm
10.7 cm
16.8 cm
154 g
Limited warranty - 5 years
50 °C
5 - 95% (non-condensing)
Drop Specification
1.8 m to concrete
Brand: Zebra
