Zebra DS6878-HC Healthcare Scanner
Quicklinx: CS1ZWS00 Mfr#: DS6878-HC2000BVZWW
Prevent medical errors, improve patient safety and increase caregiver productivity. The DS6878-HC cordless imager from Zebra enables hospitals to automate data capture, improve data accuracy, increase productivity and streamline everyday processes in patient rooms, admitting, laboratories and the pharmacy. Its matchless feature set meets the unique requirements of healthcare facilities. An intuitive and ergonomic design combines with dependable and rapid capture of barcodes and other images, allowing caregivers to remain focused on the patient - not the technology.
  • Designed for deployment on a computer or workstation on wheels (COW or WOW)
    USB charging capability eliminates a power supply and the typical cable management headaches normally associated with mounting a cordless scanner to a medical cart, computer cart or workstation (COW or WOW); horizontal or vertical installation provides the flexibility to keep the work surface clear while ensuring that the scanner is always in easy reach and charging.
  • Disinfectant-ready
    IP43 sealing and a specially designed plastic housing allow safe wipe-down and cleansing with a wide variety of harsh chemicals.
  • Lightweight ergonomic design
    Easy to hold regardless of hand size; reduces fatigue; enables all day scanning comfort to protect productivity in scan-intensive applications.
  • Superior durability
    Offers Zebra's best-in-class drop specification - the ability to survive 6 ft./1.8m drops to concrete - and IP43 sealing, ensuring reliable operation in spite of everyday spills, drops and bumps.
  • Government grade security with Zebra MAX Secure
    FIPS 140-2 certification enables compliance with the most stringent industry security regulations, including HIPAA, PCI and requirements for sensitive government applications (requires FIPS configuration scanner and CR0078-P base).
  • Comprehensive advanced data capture
    Captures 1-D and 2-D barcodes, signatures, documents such as drivers licenses and insurance cards, facial images for identification, video footage and more; eliminates the need to purchase multiple types of devices; supports the creation and maintenance of electronic medical records (EMRs).
  • Superior high-performance scanning on all barcodes
    The integrated revolutionary Zebra SE4500 imager eliminates the performance degradation common in 2-D scanning, delivering: laser-like performance on both 1-D and 2-D codes; rapid and accurate capture of even poor quality and damaged barcodes; and full omnidirectional scanning, which eliminates the need to precisely align barcode and imager, improves ergonomics and protects productivity.
  • Bluetooth v2.1 with EDR
    Provides a secure wireless connection to the scanner base station for cordless convenience and safety.
  • RSM (Remote Scanner Management) ready
    Reduces total cost of ownership by enabling remote, network-based device management of all devices in all locations.
Zebra DS6878-HC - barcode scanner
Barcode scanner - portable - Bluetooth 2.1 EDR - decoded
Healthcare white
Minimum Bar Width
5 mil
Scan Element Type
2D imager
Wireless
Wireless Connectivity
Bluetooth 2.1 EDR
6.9 cm x 9.7 cm x 18.5 cm
238 g
3-year warranty
Healthcare white
Barcode
Interface Type
Bluetooth 2.1 EDR
Minimum Bar Width
5 mil
Scan Element Type
2D imager
Light Source Wave Length
655 nm
Scan Mode
Single-pass
Skew (Degrees)
60
Pitch (Degrees)
60
Print Contrast Signal (PCS)
25%
Decode Capability
EAN/JAN, Code 93, Matrix 2 of 5, Code 39, UCC/EAN-128, ISBT 128, NW-7, IATA, ISBN, GS1 DataBar, QR code, MaxiCode, Aztec code, Bookland, Code 32, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Discrete 2 of 5, MicroPDF417, Italy Pharmacode, Codabar, Code 11, Code 2 of 5, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, ITF, PLANET, TLC39, Australian Post, British Post, Japanese Post, Kix (Netherlands) Post, IATA 2 of 5, UPC-E1, UPC-A/EAN-13 with Extended Coupon Code, EAN-UCC Composite, ISSN, UK Post, Royal Mail, Micro QR code, 4-State postal code, CC-A, CC-B, CC-C, GS1 DataBar Omnidirectional, GS1 DataBar Expanded, GS1 DataBar Expanded Stacked, GS1 DataBar Limited
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
Triggered, Reduced Space Symbology (RSS), waterproof, dustproof
Bluetooth 2.1 EDR
CISPR 24, Bluetooth Class 1, CISPR 22, ICES-003 Class B, FCC Part 15 B, RoHS, FCC CFR21 Part 1040, UL 60950-1, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60601-1-2, IEC 60529 IP43, CSA C22.2 No. 60950-1, EN 60825-1
Power adapter - external
Software
Software Included
Drivers & Utilities
6.9 cm
9.7 cm
18.5 cm
238 g
Limited warranty - 3 years
50 °C
5 - 95% (non-condensing)
Drop Specification
1.8 m to concrete
