Zebra DS3678 Ultra Rugged Scanner
Quicklinx: CRZQWS00 Mfr#: DS3678-HP2F003VZWW
Type: Barcode scanner
Form Factor: Portable
Compatibility: PC
£481.59 ex VAT
£577.90 inc VAT
As a member of the Zebra 3600 Ultra-Rugged Series of scanners, the practically indestructible DS3678-HP cordless scanner is ready for the world's toughest environments - the warehouse and manufacturing floor.
In addition to capturing virtually any 1D or 2D barcode as far as 7 ft./2.1 m away, these scanners give you the flexibility to capture a wide range of business information to streamline many everyday business processes, including OCR, documents and photos.
No matter what types of data your workers need to capture, you get all the features you need for truly unstoppable performance, redefining scanner reliability and management simplicity. The result? The dependable, fast and accurate scanning you need to take the quality of your products and your customer service to the next level.
  • Superior performance
    Your workers can capture information as fast as they can pull the trigger - from virtually any electronic or printed barcode in any condition to photos that can provide undisputable proof of condition for incoming shipments, plus images of highly legible documents for electronic recordkeeping. Even if barcodes are damaged, dirty or poorly printed, no problem - this intelligent scanner can handle it all.
  • Ultra-rugged design
    The warehouse and manufacturing plant floor is as tough as its gets. The cordless models are dust-tight, sprayproof and waterproofed to IP67, with an IP65-sealed cradle for a complete rugged cordless solution.
  • Unrivaled manageability
    With the complimentary industry-best tools, managing these scanners couldn't be easier. You can remotely configure and upgrade your scanners, format data properly for instant transmission into your business applications, monitor battery statistics for your cordless models and more.
Zebra DS3678-HP - barcode scanner
Barcode scanner - portable - Bluetooth 4.0 - decoded
Industrial green
Minimum Bar Width
5 mil
Sensor Resolution
1280 x 960
Wireless
Wireless Connectivity
Bluetooth 4.0 LE
1 x Lithium Ion
7.6 cm x 14.2 cm x 18.5 cm
411 g
3-year warranty
Industrial green
Barcode
Interface Type
Bluetooth 4.0
Minimum Bar Width
5 mil
Sensor Resolution
1280 x 960
Max Working Distance
2.1 m
Skew (Degrees)
60
Pitch (Degrees)
60
Decode Capability
Aztec code, China Han Xin Code, Codabar, Code 11, Code 128, Code 3 of 5, Code 39, Code 93, Data Matrix, GS1 DataBar, Industrial 2 of 5, Italy Pharmacode, MaxiCode, Micro QR code, MicroPDF417, MSI-Plessey, NW-7, PDF417, QR code, TLC39, UPC/EAN supplementals, MICR E-13B, OCR-A, OCR-B
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator, vibration
Bluetooth 4.0 LE
IP67, EN 50581:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+AC:2011, RoHS, IEC 60950-1:2005 + A1:2009 + A2:2013, CAN/CSA C22.2 No. 60950-1-07, UL 60950-1 Second Edition, CU, EN 62471:2008, IEC 62471:2006, UL, VDE, EN 55022:2010/AC:2011, EN 55024:2010, EN 61000-3-2:2006+A1:2009+A2:2009, EN 61000-6-2, EN 60601-1-2:2007, EN 61000-3-3:2013, FCC CFR47 Part 15 B Class B, ICES-003 issue 5 Class B, IEC 60601-1-2:2007
1 x Lithium Ion
7.6 cm
14.2 cm
18.5 cm
411 g
Limited warranty - 3 years
-20 °C
50 °C
5 - 95% (non-condensing)
Drop Specification
2.4 m to concrete
CRZQ Zebra Standard Charging Cradle (Bluetooth, Multi Interface) In Stock £191.44
Compatibility: PC
Brand: Zebra
