Every day, workers in your warehouse and on the manufacturing plant floor scan thousands of barcodes to ensure product quality and on-time order delivery. Their productivity depends on the quality of the scanner you put in their hands. When workers need to capture 1D and 2D barcodes at standard ranges, with cordless DS3678-SR scanner, you can give them the best - unmatched rugged design, unmatched scanning performance and unrivaled manageability.
The advanced imager delivers lightning-fast capture of any 1D or 2D barcode printed on a label in virtually any condition or displayed on a screen, from near contact to nearly 5 ft. /1.5 m away. And when it comes to cordless technology, the DS3678-SR is in a class of its own, with a complete solution that includes a smart battery and Zebra"s Wi-Fi friendly mode that prevents interference with your Wi-Fi network.
- Zebra DS3678-SR - barcode scanner
- Barcode scanner - portable - Bluetooth 4.0 - decoded
- Industrial green
- Minimum Bar Width
- 3 mil
- Sensor Resolution
- 1280 x 960
- Connectivity Technology
- Wireless
- Wireless Connectivity
- Bluetooth 4.0 LE
- Battery
- 1 x Lithium Ion
- 7.6 cm x 14.2 cm x 18.5 cm
- 411 g
- 3-year warranty
- Industrial green
Barcode
- Interface Type
- Bluetooth 4.0
- Minimum Bar Width
- 3 mil
- Sensor Resolution
- 1280 x 960
- Max Working Distance
- 35 cm
- Skew (Degrees)
- 60
- Pitch (Degrees)
- 60
- Print Contrast Signal (PCS)
- 15%
- Decode Capability
- Aztec code, China Han Xin Code, Codabar, Code 11, Code 128, Code 3 of 5, Code 39, Code 93, Data Matrix, GS1 DataBar, Industrial 2 of 5, Italy Pharmacode, MaxiCode, Micro QR code, MicroPDF417, MSI-Plessey, NW-7, PDF417, QR code, TLC39, UPC/EAN supplementals
- TTL Decoding
- Decoded
- Wireless
- OK Notification
- Beeper, LED indicator, vibration
- Rugged, standard range scanning
- Bluetooth 4.0 LE
- IP67, EN 50581:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+AC:2011, RoHS, IEC 60950-1:2005 + A1:2009 + A2:2013, CAN/CSA C22.2 No. 60950-1-07, UL 60950-1 Second Edition, CU, EN 62471:2008, IEC 62471:2006, UL, VDE, EN 55022:2010/AC:2011, EN 55024:2010, EN 61000-3-2:2006+A1:2009+A2:2009, EN 61000-6-2, EN 60601-1-2:2007, EN 61000-3-3:2013, FCC CFR47 Part 15 B Class B, ICES-003 issue 5 Class B, IEC 60601-1-2:2007
- Battery
- 1 x Lithium Ion
- 7.6 cm
- 14.2 cm
- 18.5 cm
- 411 g
- Limited warranty - 3 years
- -20 °C
- 50 °C
- 5 - 95% (non-condensing)
- Drop Specification
- 2.4 m to concrete
Zebra Standard Charging Cradle (Bluetooth, Multi Interface) | In Stock | £200.07 |
