Zebra DS3608 Ultra Rugged Scanner
Quicklinx: CRZTWS00 Mfr#: DS3608-HP3U4602VZW
Type: Barcode scanner
Form Factor: Handheld
Hurry, only 1 left in stock!
£341.11 ex VAT
£409.33 inc VAT
As a member of the Zebra 3600 Ultra-Rugged Series of scanners, the practically indestructible 1D/2D DS3608-HP corded and DS3678-HP cordless scanners are ready for the world's toughest environments - the warehouse and manufacturing floor.
In addition to capturing virtually any 1D or 2D barcode as far as 7 ft./2.1 m away, these scanners give you the flexibility to capture a wide range of business information to streamline many everyday business processes, including OCR, documents and photos.
No matter what types of data your workers need to capture, you get all the features you need for truly unstoppable performance, redefining scanner reliability and management simplicity. The dependable, fast and accurate scanning you need to take the quality of your products and your customer service to the next level.
  • Superior performance
    Your workers can capture information as fast as they can pull the trigger - from virtually any electronic or printed barcode in any condition to photos that can provide undisputable proof of condition for incoming shipments, plus images of highly legible documents for electronic recordkeeping. Even if barcodes are damaged, dirty or poorly printed, no problem - this intelligent scanner can handle it all.
  • Ultra-rugged design
    The warehouse and manufacturing plant floor is as tough as its gets. The corded and cordless models are the only scanners in this class that are dust-tight, sprayproof and waterproofed to IP67, with an IP65-sealed cradle for a complete rugged cordless solution.
  • Unrivaled manageability
    With the complimentary industry-best tools, managing these scanners couldn't be easier. You can remotely configure and upgrade your scanners, format data properly for instant transmission into your business applications, monitor battery statistics for your cordless models and more.
Zebra DS3608-HP - barcode scanner
Barcode scanner - handheld - USB - decoded
Industrial green
Minimum Bar Width
3 mil
Sensor Resolution
1280 x 960
Wired
7.6 cm x 13.2 cm x 18.5 cm
309 g
3-year warranty
Industrial green
Barcode
Interface Type
USB
Minimum Bar Width
3 mil
Sensor Resolution
1280 x 960
Max Working Distance
35 cm
Skew (Degrees)
60
Pitch (Degrees)
60
Print Contrast Signal (PCS)
15%
Decode Capability
Code 93, Industrial 2 of 5, Code 39, NW-7, GS1 DataBar, QR code, MaxiCode, Aztec code, MicroPDF417, Code 3 of 5, Italy Pharmacode, Codabar, Code 128, Code 11, PDF417, MSI-Plessey, Data Matrix, TLC39, Micro QR code, China Han Xin Code, UPC/EAN supplementals
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator, vibration
Waterproof, dustproof, rugged
1 x USB
1 x USB cable - external
UL, VDE, EN 61000-6-2, RoHS, UL 60950-1 Second Edition, IP67, CAN/CSA C22.2 No. 60950-1-07, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60601-1-2:2007, EN 50581:2012, ICES-003 issue 5 Class B, IEC 62471:2006, EN 62471:2008, EN 60601-1-2:2007, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+AC:2011, EN 61000-3-3:2013, EN 55024:2010, EN 55022:2010/AC:2011, IEC 60950-1:2005 + A1:2009 + A2:2013, CU, FCC CFR47 Part 15 B Class B
Electric Current Required
450 mA (operating), 100 mA (standby)
7.6 cm
13.2 cm
18.5 cm
309 g
Limited warranty - 3 years
-30 °C
50 °C
5 - 95% (non-condensing)
Drop Specification
2.4 m to concrete
CRZT Zebra Adjustable Intellistand In Stock £59.29
Brand: Zebra
