Zebra DS3608 Ultra Rugged Scanner
Quicklinx: CRZTWS00 Mfr#: DS3608-HP3U4602VZW
Type: Barcode scanner
Form Factor: Handheld
Hurry, only 1 left in stock!
£343.44 ex VAT
£412.12 inc VAT
As a member of the Zebra 3600 Ultra-Rugged Series of scanners, the practically indestructible 1D/2D DS3608-HP corded and DS3678-HP cordless scanners are ready for the world's toughest environments - the warehouse and manufacturing floor.
In addition to capturing virtually any 1D or 2D barcode as far as 7 ft./2.1 m away, these scanners give you the flexibility to capture a wide range of business information to streamline many everyday business processes, including OCR, documents and photos.
No matter what types of data your workers need to capture, you get all the features you need for truly unstoppable performance, redefining scanner reliability and management simplicity. The dependable, fast and accurate scanning you need to take the quality of your products and your customer service to the next level.
  • Superior performance
    Your workers can capture information as fast as they can pull the trigger - from virtually any electronic or printed barcode in any condition to photos that can provide undisputable proof of condition for incoming shipments, plus images of highly legible documents for electronic recordkeeping. Even if barcodes are damaged, dirty or poorly printed, no problem - this intelligent scanner can handle it all.
  • Ultra-rugged design
    The warehouse and manufacturing plant floor is as tough as its gets. The corded and cordless models are the only scanners in this class that are dust-tight, sprayproof and waterproofed to IP67, with an IP65-sealed cradle for a complete rugged cordless solution.
  • Unrivaled manageability
    With the complimentary industry-best tools, managing these scanners couldn't be easier. You can remotely configure and upgrade your scanners, format data properly for instant transmission into your business applications, monitor battery statistics for your cordless models and more.
Zebra DS3608-HP - barcode scanner
Barcode scanner - handheld - USB - decoded
Industrial green
Minimum Bar Width
3 mil
Sensor Resolution
1280 x 960
Wired
7.6 cm x 13.2 cm x 18.5 cm
309 g
3-year warranty
Industrial green
Barcode
Interface Type
USB
Minimum Bar Width
3 mil
Sensor Resolution
1280 x 960
Max Working Distance
35 cm
Skew (Degrees)
60
Pitch (Degrees)
60
Print Contrast Signal (PCS)
15%
Decode Capability
Aztec code, China Han Xin Code, Codabar, Code 11, Code 128, Code 3 of 5, Code 39, Code 93, Data Matrix, GS1 DataBar, Industrial 2 of 5, Italy Pharmacode, MaxiCode, Micro QR code, MicroPDF417, MSI-Plessey, NW-7, PDF417, QR code, TLC39, UPC/EAN supplementals
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator, vibration
Rugged, dustproof, waterproof
1 x USB
1 x USB cable - external
IP67, EN 50581:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+AC:2011, RoHS, IEC 60950-1:2005 + A1:2009 + A2:2013, CAN/CSA C22.2 No. 60950-1-07, UL 60950-1 Second Edition, CU, EN 62471:2008, IEC 62471:2006, UL, VDE, EN 55022:2010/AC:2011, EN 55024:2010, EN 61000-3-2:2006+A1:2009+A2:2009, EN 61000-6-2, EN 60601-1-2:2007, EN 61000-3-3:2013, FCC CFR47 Part 15 B Class B, ICES-003 issue 5 Class B, IEC 60601-1-2:2007
Electric Current Required
100 mA (standby), 450 mA (operating)
7.6 cm
13.2 cm
18.5 cm
309 g
Limited warranty - 3 years
-30 °C
50 °C
5 - 95% (non-condensing)
Drop Specification
2.4 m to concrete
Brand: Zebra
